Dear All,
When an asynchronous “stream” is not created using the function “cudaStreamCreate()”, could you let me know what numeric I should insert to the 4th argument of the function “cudaMemPrefetchAsync” ?
I suppose it is “0”. Am I right ?
cudaMemPrefetchAsync( X, X, X, 0 )
You can pass in “0”, though since a stream type is defined as an integer(kind=8), you might want to use “0_8” instead.
Or use variable defined as a “cuda_stream_kind”
integer(kind=cuda_stream_kind) :: stream
stream = 0
-Mat
Dear Mat-san,
Understood. Thank you for the reply.
Sincerely yours,
