cudaMemset bug cudaMemset, is it really so slow ??
Hey,
I was surprised when i tried out to check the performance of cudaMemset(), it consistently clocks ~ 7-8 GB/s (on the Quadro 5600Fx)
(a sample code which measures the performance is attached)
[codebox]int n = 1 << 27;
if (argc > 1)
	n = atoi(argv[1]);
int size = n * sizeof(int);
int* d_idata;
    cutilSafeCall( cudaMalloc( (void**) &d_idata, size));
unsigned int timer;
    cutCreateTimer(&timer);
cutResetTimer(timer);
cudaThreadSynchronize();
    cutStartTimer(timer);
//warmup
int it_wrmup = 27;
for (int i=0; i < it_wrmup; i++)
    cutilSafeCall( cudaMemset( d_idata, 0, size));
// check if kernel execution generated and error
    cutilCheckMsg("Kernel execution failed");
    cutStopTimer(timer);
    float time = cutGetTimerValue(timer)/it_wrmup;
Data-size:134217728 ints(0.500000 GB) Time:74.76 ms Through-put:7.181636 GB/s
[/codebox]
This, is awfully slow for such a primitive operation, I would expect performances comparable to cudaMemcpy () (~ 60 GB/s)!!
I guess a simple two-line fill-kernel, would be faster…
Is this a bug with the cudaMemset() or some other issue ??
cudamemset_test.cu (1.2 KB)
I haven’t tested it recently but I’ve certainly experienced the same thing in the past. I’m guessing I was probably using CUDA 2.0 at the time. I wrote a simple kernel to do it instead (as you suggest) and I haven’t really worried about it since.
