Hi all,
I have a question,
cudaMemset run by kernel or DMA (direct memory access)
please help me answer this question
thanks,
cucumber
Hi all,
I have a question,
thanks,
cucumber
You should be able to find out by running a simple test program with the CUDA profiler. On my system with CUDA 6.5, the following shows a kernel being run.
#include <stdio.h>
#include <stdlib.h>
// Macro to catch CUDA errors in CUDA runtime calls
#define CUDA_SAFE_CALL(call) \
do { \
cudaError_t err = call; \
if (cudaSuccess != err) { \
fprintf (stderr, "Cuda error in file '%s' in line %i : %s.\n",\
__FILE__, __LINE__, cudaGetErrorString(err) ); \
exit(EXIT_FAILURE); \
} while (0)
int main (void)
float *test = 0;
CUDA_SAFE_CALL (cudaMalloc ((void**)&test, 100));
CUDA_SAFE_CALL (cudaMemset (test, 0, 100));
CUDA_SAFE_CALL (cudaFree (test));
return EXIT_SUCCESS;
The profiler log shows:
# NV_Warning: The legacy Command Line Profiler is deprecated and will be no longer available as of the next major release of the CUDA toolkit. Please use nvprof.
# CUDA_PROFILE_LOG_VERSION 2.0
# CUDA_DEVICE 0 Quadro 2000
# CUDA_CONTEXT 1
# TIMESTAMPFACTOR 13f2e81a05c2b6f0
method,gputime,cputime,occupancy
method=[ memset32_post ] gputime=[ 5.184 ] cputime=[ 10.263 ] occupancy=[ 0.333 ]
Hi njuffa,
Thanks for your answer.
Best Regards,
cucumber
