Maybe I’m loosing my mind but I can’t seem to avoid C4267 warnings when using cudaOccupancyMaxPotentialBlockSize in CUDA 7 VS2012.
Compiler output.
1>C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v7.0\include\cuda_runtime.h(1541): warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v7.0\include\cuda_runtime.h(1623) : see reference to function template instantiation 'cudaError_t cudaOccupancyMaxPotentialBlockSizeVariableSMemWithFlags<__cudaOccupancyB2DHelper,void(__cdecl *)(unsigned int *,unsigned int *)>(int *,int *,T,UnaryFunction,int,unsigned int)' being compiled
1> with
1> [
1> T=void (__cdecl *)(unsigned int *,unsigned int *),
1> UnaryFunction=__cudaOccupancyB2DHelper
1> ]
1> C:/my_example/simulation.cu(384) : see reference to function template instantiation 'cudaError_t cudaOccupancyMaxPotentialBlockSize<void(__cdecl *)(unsigned int *,unsigned int *)>(int *,int *,T,size_t,int)' being compiled
1> with
1> [
1> ]
Line 384 makes the following call
cudaOccupancyMaxPotentialBlockSize( &minGridSize, &blockSize, my_kernel, 0, count);
where minGridSize, blockSize and count are all ints according to the API docs.
Any suggested fix for this other than using a pragma disable?
Paul
