Hi all,
I just installed the CudaVisualProfiler 1.1beta on my system (Xubuntu 8.04 64bits) GTX 280. Everything seems fine during installation but then when I tried to run the profiler I got the next message:
“/usr/local/cuda/CudaVisualProfiler/bin/cudaprof: No such file or directory”
Did this ever get resolved? I have the same problem as the poster did.
That is, any attempt to run cudaprof will result in “No such file or directory”
The file is there, I can even use auto-complete when going to try and launch it.
I am also running 64 bit Ubuntu 8.04 with a 280.
I tried both the 1.1 and 1.0 versions of the profiler, both gave the same error.
It will run on my Fedora box.
running “file” on it says that it is a 32 bit application. Could the problem be related to that?
