cudart64_90.dll
Hi, I’m getting this error:
undefined File “ctypes_init_.py”, line 348, in init
OSError: [WinError 126] Impossibile trovare il modulo specificatoPyInstallerImportError: Failed to load dynlib/dll ‘cudart64_90.dll’. Most probably this dynlib/dll was not found when the application was frozen.
I double check the path, and it seems to me that cudart64_90.dll is where it is supposed to be, C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\bin
Any tips?
Is this directory in the PATH environment variable?
I guess, take a look here: [url]https://drive.google.com/file/d/1xL9DVwUROT7ssvCYgicfp8qj_37s3T2f/view?usp=sharing[/url]
Are you able to write (or copy) a simple vectorAdd program, compile and run?
We have to know if it is a system-wide issue or Python-only.
If you don’t manage to compile and run a vectorAdd, there is problem in your installation and you will need to go item by item of the installation notes.
And more: are you using a Windows version of Python or an ambient like MSYS2?
