Hi
This is the sample project i got it from cuda sdk, i compiled this project in x64bit there is no errors.
When i run the project in the debug mode it exists the process, and i see an error in the result window
“cudasafecall() Runtime API Error: unspecified driver error”
so im unable to say whether this particular macro fails or cuda programs are not running
i tried to compile other projects and run, all are same, it compiles and while running it exists and shows this error
i updated the latest graphics drivers too,
if any one faced this problem before, pls help me out, with out fixing this its getting harder to proceed further
Thankyou
#include <stdio.h>
#include <stdlib.h>
#include <cutil_inline.h>
#include "clock_kernel.cu"
// This example shows how to use the clock function to measure the performance of
// a kernel accurately.
// Blocks are executed in parallel and out of order. Since there's no synchronization
// mechanism between blocks, we measure the clock once for each block. The clock
// samples are written to device memory.
#define NUM_BLOCKS 64
#define NUM_THREADS 256
// It's interesting to change the number of blocks and the number of threads to
// understand how to keep the hardware busy.
// Here are some numbers I get on my G80:
// blocks - clocks
// 1 - 3096
// 8 - 3232
// 16 - 3364
// 32 - 4615
// 64 - 9981
// With less than 16 blocks some of the multiprocessors of the device are idle. With
// more than 16 you are using all the multiprocessors, but there's only one block per
// multiprocessor and that doesn't allow you to hide the latency of the memory. With
// more than 32 the speed scales linearly.
int main(int argc, char** argv)
// use command-line specified CUDA device, otherwise use device with highest Gflops/s
if ( cutCheckCmdLineFlag(argc, (const char **)argv, "device"))
cutilDeviceInit(argc, argv);
else
cudaSetDevice( cutGetMaxGflopsDeviceId() );
float * dinput = NULL;
float * doutput = NULL;
clock_t * dtimer = NULL;
clock_t timer[NUM_BLOCKS * 2];
float input[NUM_THREADS * 2];
for (int i = 0; i < NUM_THREADS * 2; i++)
input[i] = (float)i;
cutilSafeCall(cudaMalloc((void**)&dinput, sizeof(float) * NUM_THREADS * 2));
cutilSafeCall(cudaMalloc((void**)&doutput, sizeof(float) * NUM_BLOCKS));
cutilSafeCall(cudaMalloc((void**)&dtimer, sizeof(clock_t) * NUM_BLOCKS * 2));
cutilSafeCall(cudaMemcpy(dinput, input, sizeof(float) * NUM_THREADS * 2, cudaMemcpyHostToDevice));
timedReduction<<<NUM_BLOCKS, NUM_THREADS, sizeof(float) * 2 * NUM_THREADS>>>(dinput, doutput, dtimer);
//cutilSafeCall(cudaMemcpy(output, doutput, sizeof(float) * NUM_BLOCKS, cudaMemcpyDeviceToHost));
cutilSafeCall(cudaMemcpy(timer, dtimer, sizeof(clock_t) * NUM_BLOCKS * 2, cudaMemcpyDeviceToHost));
cutilSafeCall(cudaFree(dinput));
cutilSafeCall(cudaFree(doutput));
cutilSafeCall(cudaFree(dtimer));
// This test always passes.
printf( "Test PASSED\n");
// Compute the difference between the last block end and the first block start.
clock_t minStart = timer[0];
clock_t maxEnd = timer[NUM_BLOCKS];
for (int i = 1; i < NUM_BLOCKS; i++)
minStart = timer[i] < minStart ? timer[i] : minStart;
maxEnd = timer[NUM_BLOCKS+i] > maxEnd ? timer[NUM_BLOCKS+i] : maxEnd;
printf("time = %d\n", maxEnd - minStart);
cudaThreadExit();
cutilExit(argc, argv);
