I have a question regarding cudaThreadSynchronize() and cudaStreamSynchronize(). At the moment I am basically doing the following:
void mySolver()
for (int i=0; i<maxSteps; ++i)
kernel1<<dimGrid,dimBlock,stream1>>();
kernel2<dimGrid,dimBlock,stream2>>();
kernel3<dimGrid,dimBlock,stream2>>();
kernel4<dimGrid,dimBlock,stream2>>();
kernel5<dimGrid,dimBlock,stream2>>();
cudaStreamSynchronize(stream1);
kernel6<dimGrid,dimBlock,stream2>>();
cudaStreamSynchronize(stream2);
and I am timing mySolver() with the wall clock time.
startTime = wall_clock();
mySolver();
stopTime = wall_clock();
When I change the parameter maxSteps I am observing the following run times
maxSteps | wall clock time
10 | 0.121 ms
20 | 0.202 ms
30 | 0.290 ms
40 | 0.363 ms
50 | 0.442 ms
100 | 0.944 ms
150 | 2.381 ms
200 | 31.513 ms
238 | 53.640 ms
As the computational work does not change during the iteration i can not really explain that behavior. If i add
at the end of mySolver() the howl thing gets much slower but the behavior regarding the number of iterations is mor as expected. So my Questions are
What exactly is doing cudaThreadSyncronize() more than cudaStreamSynchronize()?
- Why does the runtime of the cudaStreamSynchronize() version does not scale with the number of iterations?
Best regards
Jiri Kraus
