I’m programming an extension for python to use some cuda functions, in a linux 32bit box. The module run ok without any cuda functions, but when I enable cuda functions it execute ok but end with an segmentation fault.
To check what is happening I used the python debugger and the gdb debugger. The following traceback I got at the end of the execution:
font=“Courier” backtrace #0 0xb7ac701d in ?? () from /usr/local/share/cuda/lib/libcudart.so #1 0x00000001 in ?? () #2 0x000000d9 in ?? () #3 0xbff3e6a4 in ?? () #4 0xbff3e6e8 in ?? () #5 0xb7ab67a6 in __cudaUnregisterFatBinary () from /usr/local/share/cuda/lib/libcudart.so
Backtrace stopped: frame did not save the PC[/font]
I was testing other ways to init with context but it doesnt work.
I wrote a simple test code to compile with nvcc and python. I feel it’s a compiling problem, but I can’t understand why. Here I append the simple code.
That function try to clean all resources used in the shared object, but python clean all resources before.
I could use my python module without segfault compiling with gcc argument “-nostartfiles”, but I dont know if that function clean other resources used in the device.
But if I want to use cufft or other library, I got the same segfault. It’s because I cant link these library with that options.
Is possible to remove that functions in the libraries and append a user function to clean the resources the API?
I feel CUDA have a list of vector of allocated segments by cudaMalloc, but Python capture thats allocs and dealloc them at the end of the execution, before free libraries & modules. I will write to the python developer team to check it.
We are in the process of wrapping all the cuda libraries into python using ctypes and are seeing the same issue - but only with cublas and cufft. This problem wasn’t there in the 0.8 release. Here is a simply python script (no compilation needed) that demonstrates the problem:
############ Begin Python script #############
“”"A simple python script showing segfaults on exit.
This script uses the ctypes packages to dynamically load the CUDA
libraries. We have been using this approach successfully since the
0.8 release of CUDA and it has worked extremely well. This script
will run out of the box with Python 2.5 (ctypes comes with Python 2.5)
and will also run on Python 2.4 if ctypes is downloaded and installed
separately.
I don’t think we had this problem with CUDA 0.8.
Run the script by doing:
$ python test_segfault.py
from ctypes import *
Uncomment a particular library to see its effect. It is important
to note that even though these segfault on exit, they can be
I am getting this problem as well, when using CUDA inside a shared library. No matter if I actually do any CUDA stuff, when the application closes I get:
Caught SIGSEGV accessing address 0x61 #0 0x00002b7dfafe8d4f in waitpid () from /lib/libpthread.so.0 #1 0x00002b7dfad4d3f0 in g_on_error_stack_trace () #2 0x0000000000402bac in ?? () #3 #4 0x0000000000000061 in ?? () #5 0x00002aaaab51523b in __cudaUnregisterFatBinary () #6 0x00002aaaab73ee62 in __do_global_dtors_aux () #7 0x00007fffb0c94390 in ?? () #8 0x00002aaaab78dc01 in _fini () from /home/wladimir/lib/libcudawavelet.so #9 0x0000000000000000 in ?? ()
I’m using CUDA as a shared library as well. And here what I got:
#0 0x00000031 in ?? ()
#1 0xb523def5 in __cudaUnregisterFatBinary () from /usr/local/cuda/lib/libcudart.so
#2 0xb5442a70 in __cudaUnregisterBinary () from /home/.../linux/lib/libmilx-CudaStuff.so
#3 0xb543e430 in __do_global_dtors_aux () from /home/.../linux/lib/libmilx-CudaStuff.so
#4 0xb544688c in _fini () from /home/.../linux/lib/libmilx-CudaStuff.so
#5 0xb7f374ce in _dl_rtld_di_serinfo () from /lib/ld-linux.so.2
#6 0xb72a9299 in exit () from /lib/tls/i686/cmov/libc.so.6
#7 0xb72928d4 in __libc_start_main () from /lib/tls/i686/cmov/libc.so.6
#8 0x080517e1 in _start ()
I’m not sure I got a segmentation fault with CUDA 0.8. But I might be wrong. Apparently it’s a known bug. So we just have to wait I reckon.
