Cudla input Tensort, output Tensort data layout, quantization, and inverse quantization issues
Software Version
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
[*] DRIVE OS 6.0.4 SDK
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] DRIVE AGX Orin Developer Kit (not sure its number)
other
SDK Manager Version
1.9.2.10884
[*] other
Host Machine Version
[*] other
I ran a command
./cuDLAStandaloneMode …/model_test/joint_model_cygnus_simple_batch1_512960_230220_dla_opt_sub_1.cudla 2
The output tensor information is as follows
Printing input tensor descriptor
TENSOR NAME : input’
dims: [1, 4, 512, 960]
data fmt: 2
data type: 4
data category: 0
pixel fmt: 12
pixel mapping: 0
stride[0]: 1
stride[1]: 3840
stride[2]: 0
stride[3]: 0
-----------------------------------------tensor input:0
Printing output tensor descriptor
TENSOR NAME : M0_519’
dims: [1, 64, 32, 60]
data fmt: 1
data type: 4
data category: 3
pixel fmt: 0
pixel mapping: 0
stride[0]: 1
stride[1]: 64
stride[2]: 2048
stride[3]: 2048
-----------------------------------------tensor output:0
CUDLA_DATA_FORMAT_NHWC,The format of the input tensor is CUDLA_DATA_FORMAT_NHWC and the type is int8.
I have an input to an NCHW float, and I should get the quantization parameters and write them into input tensor in CUDLA_DATA_FORMAT_NHWC format.I don’t quite understand what this street means.
Then where can I get the quantized parameters of Tensor.
The output tensort is int8, CUDLA_ DATA_ FORMAT_ NCHW format. How should I inversely convert it to float 32 and convert it to nchw format.
I didn’t find its scale and zero in the model for either Tensor_ Parameter of point
Dear @haihua.wei,
I just want to confirm if you have flashed DRIVE OS using sdkmanager with Devzone credentials? or you have received DRIVE OS via NVOnline?
We have a standard drive OS.
Dear @haihua.wei,
May I know the path of cuDLAStandaloneMode?
cuDLA samples:
▪ cuDLAStandaloneMode - cuda-samples/Samples/4_CUDA_Libraries/cuDLAStandaloneMode at master · NVIDIA/cuda-samples · GitHub
@SivaRamaKrishnaNV
I need code that runs cuDLAStandaloneMode with the right results, not just a performance test。
@SivaRamaKrishnaNV
Dear @haihua.wei , I did not get this.
I see this sample is part of CUDA 11.6 in github? Did you test running it with DRIVE OS 6.0.4 which has CUDA 11.4? Please provide me the input file/ steps to reproduce the issue.
