CUDNN 9 on Jetson ORIN NX 16g and JetPack 6.0
I am following instructions that require CuDNN 9.0 for ORIN NX. How should i install it?When I installed JetPack 6.0, CuDNN 8.9.4.25 was installed.
$ pip install "git+https://github.com/facebookresearch/pytorch3d.git@stable"
Collecting git+https://github.com/facebookresearch/pytorch3d.git@stable
  Cloning https://github.com/facebookresearch/pytorch3d.git (to revision stable) to /tmp/pip-req-build-8mms1cck
  Running command git clone --filter=blob:none --quiet https://github.com/facebookresearch/pytorch3d.git /tmp/pip-req-build-8mms1cck
  Running command git checkout -q 75ebeeaea0908c5527e7b1e305fbc7681382db47
  Resolved https://github.com/facebookresearch/pytorch3d.git to commit 75ebeeaea0908c5527e7b1e305fbc7681382db47
  Preparing metadata (setup.py) ... error
  error: subprocess-exited-with-error
  × python setup.py egg_info did not run successfully.
  │ exit code: 1
  ╰─> [8 lines of output]
        File "<string>", line 2, in <module>
        File "<pip-setuptools-caller>", line 34, in <module>
        File "/tmp/pip-req-build-8mms1cck/setup.py", line 15, in <module>
          import torch
        File "/home/mona/miniconda3/envs/myenv/lib/python3.10/site-packages/torch/__init__.py", line 237, in <module>
          from torch._C import *  # noqa: F403
      ImportError: libcudnn.so.9: cannot open shared object file: No such file or directory
      [end of output]
  note: This error originates from a subprocess, and is likely not a problem with pip.
error: metadata-generation-failed
× Encountered error while generating package metadata.
╰─> See above for output.
note: This is an issue with the package mentioned above, not pip.
hint: See above for details.
If this is not a possibility, can I upgrade my JetPack to 6.1 without losing my current setup?
I updated to JetPack 6.2 and got this error when installing the following:
mona@mona:~/librealsense_build$ sudo apt-get install git cmake libssl-dev freeglut3-dev libusb-1.0-0-dev pkg-config libgtk-3-dev unzip -y
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
pkg-config is already the newest version (0.29.2-1ubuntu3).
freeglut3-dev is already the newest version (2.8.1-6).
cmake is already the newest version (3.22.1-1ubuntu1.22.04.2).
git is already the newest version (1:2.34.1-1ubuntu1.12).
libgtk-3-dev is already the newest version (3.24.33-1ubuntu2.2).
libssl-dev is already the newest version (3.0.2-0ubuntu1.18).
libusb-1.0-0-dev is already the newest version (2:1.0.25-1ubuntu2).
unzip is already the newest version (6.0-26ubuntu3.2).
The following packages were automatically installed and are no longer required:
  gdal-data libaec0 libarmadillo10 libarpack2 libavcodec-dev libavformat-dev libavutil-dev libblosc1 libcfitsio9 libcharls2 libdc1394-dev libdouble-conversion3 libexif-dev libfreexl1 libfyba0 libgdal30
  libgdcm-dev libgdcm3.0 libgeos-c1v5 libgeos3.10.2 libgeotiff5 libgl2ps1.4 libglew2.2 libgphoto2-dev libhdf4-0-alt libhdf5-103-1 libhdf5-hl-100 libheif1 libilmbase-dev libkmlbase1 libkmldom1
  libkmlengine1 liblept5 libminizip1 libmysqlclient21 libnetcdf19 libodbc2 libodbcinst2 libogdi4.1 libopencv-calib3d4.5d libopencv-contrib4.5d libopencv-dnn4.5d libopencv-features2d4.5d
  libopencv-flann4.5d libopencv-highgui4.5d libopencv-imgcodecs4.5d libopencv-imgproc4.5d libopencv-ml4.5d libopencv-objdetect4.5d libopencv-photo4.5d libopencv-shape4.5d libopencv-stitching4.5d
  libopencv-superres4.5d libopencv-video4.5d libopencv-videoio4.5d libopencv-videostab4.5d libopencv-viz4.5d libopenexr-dev libpq5 libproj22 libraw1394-dev librttopo1 libsocket++1 libspatialite7
  libsuperlu5 libswresample-dev libswscale-dev libsz2 libtbb-dev libtesseract4 liburiparser1 libvtk9.1 libxerces-c3.2 mysql-common nvidia-cudnn9 nvidia-cudnn9-dev proj-data unixodbc-common
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
7 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up nvidia-l4t-kernel (5.15.148-tegra-36.4.3-20250107174145) ...
Using the existing boot entry 'primary'
Warning: Cannot get compatible board name.
3767-000-0000--1--recomputer-orin-j401-
TNSPEC 3767-300-0000-M.1-1-0-recomputer-orin-j401-
COMPATIBLE_SPEC 3767-000-0000--1--recomputer-orin-j401-
TEGRA_BOOT_STORAGE nvme0n1
TEGRA_CHIPID 0x23
TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
Info: Write TegraPlatformCompatSpec with 3767-000-0000--1--recomputer-orin-j401-.
Info: The esp is already mounted to /boot/efi.
Starting kernel post-install procedure.
Rootfs AB is not enabled.
ERROR. Procedure for A_kernel update FAILED.
Cannot install package. Exiting...
dpkg: error processing package nvidia-l4t-kernel (--configure):
 installed nvidia-l4t-kernel package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-headers:
 nvidia-l4t-kernel-headers depends on nvidia-l4t-kernel (= 5.15.148-tegra-36.4.3-20250107174145); however:
  Package nvidia-l4t-kernel is not configured yet.
dpkg: error processing package nvidia-l4t-kernel-headers (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of nvidia-l4t-jetson-io:
 nvidia-l4t-jetson-io depends on nvidia-l4t-kernel (>> 5.15.148-tegra-36.4-0); however:
 nvidia-l4t-jetson-io depends on nvidia-l4t-kernel (<< 5.15.148-tegra-36.5-0); however:
dpkg: error processing package nvidia-l4t-jetson-io (--configure):
No apport report written because the error message indicates its a followup error from a previous failure.
        dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-oot-modules:
 nvidia-l4t-kernel-oot-modules depends on nvidia-l4t-kernel (= 5.15.148-tegra-36.4.3-20250107174145); however:
dpkg: error processing package nvidia-l4t-kernel-oot-modules (--configure):
dpkg: dependency problems prevent configuration of nvidia-l4t-display-kernel:
 nvidia-l4t-display-kernel depends on nvidia-l4t-kernel (= 5.15.148-tegra-36.4.3-20250107174145); however:
dpkg: error processing package nvidia-l4t-display-kernel (--configure):
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-oot-headers:
 nvidia-l4t-kernel-oot-headers depends on nvidia-l4t-kernel (= 5.15.148-tegra-36.4.3-20250107174145); however:
dpkg: error processing package nvidia-l4t-kerNo apport report written because MaxReports is reached already
        nel-oot-headers (--configure):
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-dtbs:
 nvidia-l4t-kernel-dtbs depends on nvidia-l4t-kernel (= 5.15.148-tegra-36.4.3-20250107174145); however:
dpkg: error processing package nvidia-l4t-kernel-dtbs (--configure):
Processing triggers for nvidia-l4t-initrd (36.4.3-20250107174145) ...
Include /etc/nv-update-initrd/list.d/binlist
Include /etc/nv-update-initrd/list.d/modules
nv-update-initrd: Updating /boot/initrd from /etc/nv-update-initrd/list.d for kernel version 5.15.148-tegra..
Add /usr/sbin/nvluks-srv-app
Add /lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/nvidia/nvethernet/nvethernet.ko
Add /lib/modules/5.15.148-tegra/updates/drivers/nvpps/nvpps.ko
Add /lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/realtek/r8126/r8126.ko
Add /lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/realtek/r8168/r8168.ko
Add /lib/modules/5.15.148-tegra/modules*
Add /lib/modules/5.15.148-tegra/kernel/drivers/nvme/host/nvme.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/nvme/host/nvme-core.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/thermal/tegra/tegra-bpmp-thermal.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/pwm/pwm-tegra.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/hwmon/pwm-fan.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/pci/controller/dwc/pcie-tegra194.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/phy/tegra/phy-tegra194-p2u.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/usb/gadget/udc/tegra-xudc.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/usb/typec/ucsi/typec_ucsi.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/usb/typec/ucsi/ucsi_ccg.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/usb/typec/typec.ko
Updating modprobe.d configuration directories for modprobe..
Add config /etc/modprobe.d/alsa-base.conf
Add config /etc/modprobe.d/bcmdhd.conf
Add config /etc/modprobe.d/blacklist-ath_pci.conf
Add config /etc/modprobe.d/blacklist.conf
Add config /etc/modprobe.d/blacklist-firewire.conf
Add config /etc/modprobe.d/blacklist-framebuffer.conf
Add config /etc/modprobe.d/blacklist-modem.conf
Add config-link /etc/modprobe.d/blacklist-oss.conf
Add config /etc/modprobe.d/blacklist-rare-network.conf
Add config /etc/modprobe.d/denylist-nouveau.conf
Add config /etc/modprobe.d/denylist-oot-modules-audio.conf
Add config /etc/modprobe.d/denylist-ramoops.conf
Add config /etc/modprobe.d/denylist-tegra-safety.conf
Add config /etc/modprobe.d/denylist-tpm-ftpm-tee.conf
Add config /etc/modprobe.d/iwlwifi.conf
Add config /etc/modprobe.d/nvgpu.conf
Add config /etc/modprobe.d/nvidia-display.conf
Add config /etc/modprobe.d/tegra-udrm.conf
Add config /lib/modprobe.d/aliases.conf
Add config /lib/modprobe.d/fbdev-blacklist.conf
Add config /lib/modprobe.d/systemd.conf
Cleaning up the temporary directory for updating the initrd..
Errors were encountered while processing:
 nvidia-l4t-kernel
E: Sub-process /usr/bin/dpkg returned an error code (1)
Is librealsense for Intel RealSense D435 camera compatible with JetPack 6.2 on Jetson ORIN NX 16G?
log.txt (40.2 KB)o
So I first flashed with 6.1 but upon logon I was asked for software update which updated it to 6.2 and that seems like a broken update.
Anyhow, it doesn’t seem I could fix it so I am going to resort to flashing it again with 6.1
I will update here. I have attached log.txt, shows all what I tried.
Update: I flashed ORIN NX 16g with JetPack 6.1 and was able to install librealsense from source and use the Intel RealSense D435 camera.
I also have CuDNN 9.3.0.75 in this version of JetPack.
