Are there any simple examples of setting up a backend graph to do maxpooling and upsampling?
I did get maxpooling to work (made a 64x64 image down to 32x32), but it was at odds with how the docs say it should. I had to set the padding mode (CUDNN_ATTR_RESAMPLE_PADDING_MODE) to CUDNN_NEG_INF_PAD. Nothing in the docs about that. Also, I didn’t need to set the PRE/POST_PADDING attribs; docs say it’s required.
Here’s some code for maxpooling:
void create_maxpool_descriptor(cudnnBackendDescriptor_t& desc, int64_t h, int64_t w)
std::cout << "Creating Maxpool Descriptor..." << std::endl;
cudnnBackendCreateDescriptor(CUDNN_BACKEND_RESAMPLE_DESCRIPTOR, &desc);
// this is set by default to nearest...change to maxpool
int64_t resample_mode = CUDNN_RESAMPLE_MAXPOOL;
cudnnBackendSetAttribute(desc, CUDNN_ATTR_RESAMPLE_MODE, CUDNN_TYPE_RESAMPLE_MODE, 1, &resample_mode);
// Specifies the number of spatial dimensions to perform the resampling over.
int64_t spacial_dims = 2;
cudnnBackendSetAttribute(desc, CUDNN_ATTR_RESAMPLE_SPATIAL_DIMS, CUDNN_TYPE_INT64, 1, &spacial_dims);
// Spatial dimensions of filter.
int64_t window_dims[] = { h, w };
cudnnBackendSetAttribute(desc, CUDNN_ATTR_RESAMPLE_WINDOW_DIMS, CUDNN_TYPE_INT64, 2, window_dims);
// Stride in each dimension for the kernel/filter.
int64_t resample_strides[] = { h, w };
cudnnBackendSetAttribute(desc, CUDNN_ATTR_RESAMPLE_STRIDES, CUDNN_TYPE_INT64, 2, resample_strides);
// Why does maxpool only work with this padding? AVGPOOL doesn't need this.
int64_t padding_mode = CUDNN_NEG_INF_PAD;
cudnnBackendSetAttribute(desc, CUDNN_ATTR_RESAMPLE_PADDING_MODE, CUDNN_TYPE_PADDING_MODE, 1, &padding_mode);
// Why is this now not required??? Docs say we need this... stupid.
int64_t resample_paddings[] = { 0, 0 };
cudnnBackendSetAttribute(desc, CUDNN_ATTR_RESAMPLE_PRE_PADDINGS, CUDNN_TYPE_INT64, 2, resample_paddings);
cudnnBackendSetAttribute(desc, CUDNN_ATTR_RESAMPLE_POST_PADDINGS, CUDNN_TYPE_INT64, 2, resample_paddings);*/
cudnnBackendFinalize(desc);
// set up maxpool descriptor
cudnnBackendDescriptor_t maxpool_desc;
create_maxpool_descriptor(maxpool_desc, 2, 2);
std::cout << "Creating Maxpool Resample Fwd Operation..." << std::endl;
cudnnBackendDescriptor_t maxpool_op_desc;
cudnnBackendCreateDescriptor(CUDNN_BACKEND_OPERATION_RESAMPLE_FWD_DESCRIPTOR, &maxpool_op_desc);
cudnnBackendSetAttribute(maxpool_op_desc, CUDNN_ATTR_OPERATION_RESAMPLE_FWD_DESC, CUDNN_TYPE_BACKEND_DESCRIPTOR, 1, &maxpool_desc);
cudnnBackendSetAttribute(maxpool_op_desc, CUDNN_ATTR_OPERATION_RESAMPLE_FWD_XDESC, CUDNN_TYPE_BACKEND_DESCRIPTOR, 1, &image_desc);
cudnnBackendSetAttribute(maxpool_op_desc, CUDNN_ATTR_OPERATION_RESAMPLE_FWD_YDESC, CUDNN_TYPE_BACKEND_DESCRIPTOR, 1, &resampled_desc);
cudnnBackendFinalize(maxpool_op_desc);
That seems to work, even though the graph creation stuff flips out.
As for upsampling…yeah, no. Nada, zip, zero. Nothing I do works. Here’s the code:
void create_upsample_descriptor(cudnnBackendDescriptor_t& desc, int64_t h, int64_t w)
std::cout << "Creating Upsample Descriptor..." << std::endl;
int64_t resample_mode = CUDNN_RESAMPLE_NEAREST;
int64_t resample_strides[] = { 2, 2 };
/*int64_t padding_mode = CUDNN_EDGE_VAL_PAD;
cudnnBackendSetAttribute(desc, CUDNN_ATTR_RESAMPLE_PADDING_MODE, CUDNN_TYPE_PADDING_MODE, 1, &padding_mode);*/
/*int64_t resample_paddings[] = { 0, 0 };
// set up upsample descriptor
cudnnBackendDescriptor_t upsample_desc;
create_upsample_descriptor(upsample_desc, 2, 2);
std::cout << "Creating Upsample Resample Fwd Operation..." << std::endl;
cudnnBackendDescriptor_t upsample_op_desc;
cudnnBackendCreateDescriptor(CUDNN_BACKEND_OPERATION_RESAMPLE_FWD_DESCRIPTOR, &upsample_op_desc);
cudnnBackendSetAttribute(upsample_op_desc, CUDNN_ATTR_OPERATION_RESAMPLE_FWD_DESC, CUDNN_TYPE_BACKEND_DESCRIPTOR, 1, &upsample_desc);
cudnnBackendSetAttribute(upsample_op_desc, CUDNN_ATTR_OPERATION_RESAMPLE_FWD_XDESC, CUDNN_TYPE_BACKEND_DESCRIPTOR, 1, &resampled_desc);
cudnnBackendSetAttribute(upsample_op_desc, CUDNN_ATTR_OPERATION_RESAMPLE_FWD_YDESC, CUDNN_TYPE_BACKEND_DESCRIPTOR, 1, &upsampled_desc);
cudnnBackendFinalize(upsample_op_desc);
Are there any examples of upsampling? Or at least better docs? Or at least better examples that don’t have errors or skip things? Or at lease better errors? Because this sh*t doesn’t help:
Error: CUDNN_STATUS_BAD_PARAM; Reason: finalize_internal()
Thanks,
-Chris
EDIT: And just in case, here’s how I build the tensor descriptors:
void create_tensor_descriptor(cudnnBackendDescriptor_t& desc, int64_t n, int64_t c, int64_t h, int64_t w, int64_t uid)
std::cout << "Creating Tensor Descriptor..." << std::endl;
cudnnBackendCreateDescriptor(CUDNN_BACKEND_TENSOR_DESCRIPTOR, &desc);
cudnnDataType_t dtype = CUDNN_DATA_FLOAT;
int64_t alignment = 4;
cudnnBackendSetAttribute(desc, CUDNN_ATTR_TENSOR_DATA_TYPE, CUDNN_TYPE_DATA_TYPE, 1, &dtype);
cudnnBackendSetAttribute(desc, CUDNN_ATTR_TENSOR_BYTE_ALIGNMENT, CUDNN_TYPE_INT64, 1, &alignment);
int64_t xDim[] = { n, c, h, w };
int64_t xStr[] = { c * h * w, h * w, w, 1 };
cudnnBackendSetAttribute(desc, CUDNN_ATTR_TENSOR_DIMENSIONS, CUDNN_TYPE_INT64, 4, &xDim);
cudnnBackendSetAttribute(desc, CUDNN_ATTR_TENSOR_STRIDES, CUDNN_TYPE_INT64, 4, &xStr);
cudnnBackendSetAttribute(desc, CUDNN_ATTR_TENSOR_UNIQUE_ID, CUDNN_TYPE_INT64, 1, &uid);
Also, why is there no upsample in the cudnn_ops_infer.so library? It has pooling…
