CuDNN: Issue with Setting Up RNN DescriptorV8
Hi i am learning CUDA and trying to setup a RNN using CuDNN. However, i stuck at the cudnnSetRNNDescriptor_v8 function, which keeps returning a status code 9 (CUDNN_STATUS_NOT_SUPPORTED). From what i read in the documentation it means that the combination of parameters im using isn’t supported. I check the arguments, and try change some of the parameter but unable to resolve the issue. While the code compiles fine, it always return me the status code 9.
#include <cuda_runtime.h>
#include <iostream>
#include <cudnn.h>
using namespace std;
int main() {
    // Create a cuDNN handle
    cudnnHandle_t handle;
    cudnnCreate(&handle);
    // Define RNN descriptor
    cudnnRNNDescriptor_t rnnDesc;
    cudnnCreateRNNDescriptor(&rnnDesc);
    int inputSize = 100;
    int hiddenSize = 64;
    int projSize = 32;
    int numLayers = 2;
    cudnnDropoutDescriptor_t dropoutDesc;
    cudnnCreateDropoutDescriptor(&dropoutDesc);
    float dropout = 0.5;
    cudnnStatus_t cudnnStatus = cudnnSetDropoutDescriptor(
        dropoutDesc, handle, dropout, NULL, 0, 1234);
    cout<<"STATUS FOR DROP OUT: "<<cudnnStatus<<endl;
    cudnnRNNAlgo_t algo = CUDNN_RNN_ALGO_STANDARD;
    cudnnRNNMode_t cellMode = CUDNN_RNN_RELU;
    cudnnRNNBiasMode_t biasMode = CUDNN_RNN_NO_BIAS;
    cudnnDirectionMode_t dirMode = CUDNN_UNIDIRECTIONAL;
    cudnnRNNInputMode_t inputMode = CUDNN_LINEAR_INPUT;
    cudnnDataType_t dataType = CUDNN_DATA_FLOAT;
    cudnnDataType_t mathPrec = CUDNN_DATA_FLOAT;
    cudnnMathType_t mathType = CUDNN_DEFAULT_MATH;
    cudnnStatus_t status= cudnnSetRNNDescriptor_v8(rnnDesc, algo,
    cellMode, biasMode, dirMode, inputMode,
    dataType, mathPrec, mathType,
    inputSize,hiddenSize,  projSize,numLayers,dropoutDesc,
    CUDNN_RNN_PADDED_IO_DISABLED);
    cout<<"RNN STATUS: "<<status<<endl;
    return 0;
OUTPUT:
STATUS FOR DROP OUT: 0
RNN STATUS: 9
Could someone with expertise in CuDNN help me identify what might be causing this issue? Any insights or suggestions would be greatly appreciated.
