CuDNN issues while compiling opencv from source
Hi there, I’ve been trying to compile opencv from source with cuda and CuDNN support, i was following the tutorial, : Compiling OpenCV from Source | OpenCV | RidgeRun, I have successfully compiled for the Jetson Nano. but I find it particularly troublesome for the Jetson Xavier Nx.
While running the make -j6 command, I get various verbose outputs during the make process, which are related to the symbolic links of the cudnn.
While checking the sudo ldconfig I get the following output:
/sbin/ldconfig.real: /usr/local/cuda-10.2/targets/aarch64-linux/lib/libcudnn_adv_infer.so.8 is not a symbolic link
/sbin/ldconfig.real: /usr/local/cuda-10.2/targets/aarch64-linux/lib/libcudnn_adv_train.so.8 is not a symbolic link
/sbin/ldconfig.real: /usr/local/cuda-10.2/targets/aarch64-linux/lib/libcudnn.so.8 is not a symbolic link
/sbin/ldconfig.real: /usr/local/cuda-10.2/targets/aarch64-linux/lib/libcudnn_cnn_infer.so.8 is not a symbolic link
/sbin/ldconfig.real: /usr/local/cuda-10.2/targets/aarch64-linux/lib/libcudnn_cnn_train.so.8 is not a symbolic link
/sbin/ldconfig.real: /usr/local/cuda-10.2/targets/aarch64-linux/lib/libcudnn_ops_train.so.8 is not a symbolic link
/sbin/ldconfig.real: /usr/local/cuda-10.2/targets/aarch64-linux/lib/libcudnn_ops_infer.so.8 is not a symbolic link
How can I solve this issue?
Could you give the below script a try?
