If i have two separate layers, let’s say layer L1 and layer L2, that both receive the same or different inputs. Would it be possible to merge the outputs of L1 and L2 to create an input for the next layer L3?
As far as i can see i can only merge layers by first shifting the output data from L1 in certain regions and then injecting the output data from L2 in the resulting empty regions. However this would be a time consuming process. Did the designers take this into account? Is there some internal mechanism to deal with this?
