I have one jetson NX with Jetpack4.6.
I download docker image with command [sudo docker pull nvcr.io/nvidia/l4t-base:r32.6.1]。
And I build a new image with an ordinary user from dockerfile, the command in dockerfile is below:
FROM l4t-base:r32.6.1:latest
RUN apt -y install sudo
RUN useradd -m ecbu && echo "ecbu:111111" | chpasswd && adduser ecbu sudo
ENV LANG C.UTF-8
WORKDIR /home/ecbu
USER ecbu
I install cudnn,and run cudnn sample in mnistcudnn.
It success in root but failed in ecbu,below is the result:
ERROR: cuda failure (no CUDA-capable device is detected)
