I’m encountering an issue while trying to implement a Batch Normalization operation using cuDNN’s backend API. When setting the CUDNN_ATTR_ENGINE_GLOBAL_INDEX attribute for the engine descriptor, I’m receiving a CUDNN_STATUS_NOT_SUPPORTED error. This occurs even when setting the index to 0, which should be valid according to the documentation.
Here’s a snippet of the relevant code:
cudnnBackendDescriptor_t engine;
CHECK_CUDNN(cudnnBackendCreateDescriptor(CUDNN_BACKEND_ENGINE_DESCRIPTOR, &engine));
CHECK_CUDNN(cudnnBackendSetAttribute(engine, CUDNN_ATTR_ENGINE_OPERATION_GRAPH,
CUDNN_TYPE_BACKEND_DESCRIPTOR, 1, &opGraph));
int64_t gidx = 0;
CHECK_CUDNN(cudnnBackendSetAttribute(engine, CUDNN_ATTR_ENGINE_GLOBAL_INDEX,
CUDNN_TYPE_INT64, 1, &gidx));
CHECK_CUDNN(cudnnBackendFinalize(engine));
The error occurs on the line where CUDNN_ATTR_ENGINE_GLOBAL_INDEX is set. I’ve verified that the operation graph is created successfully before this point.
Environment details:
- cuDNN version: [9.2]
- CUDA version: 12.4
- GPU model: 2080TI
- Operating System: ubuntu
I’ve reviewed the documentation and can’t find any indication that Batch Normalization operations should not support engine global indices. Has anyone encountered a similar issue or can provide insight into why this might be happening? Are there any known limitations or requirements for using engine global indices with Batch Normalization operations that I might be missing?
Any help or guidance would be greatly appreciated. Thank you in advance for your assistance.
