So I’m currently working with GPT2 running on Tensorflow for text generation. I’m working with this repo specifically. I recently decided to install CUDA and cudnn to improve GPU capability and installed it via these instructions. I’m currently using Windows 10 x64 with NVIDIA Geforce GTX 1650 for my GPU and I’m using the command prompt terminal. I followed the instructions as best I could: downloaded the right GPU driver, set environment variables, copied cudnn files where they should go, etc. When I finished installing, I tried to generate an unconditional sample with the model I trained and I got an OOM error (would show it here, but it’s super long).
Assuming that I installed something incorrectly, I messed around with some of the CUDA files. I found that when I removed cudnn64_8.dll from C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.4\bin where I was told to copy it and then ran an unconditional sample, GPT2 worked just fine and was able to generate some text. All the other cudnn files were still in their CUDA directories.
Another thing I tried was adding TF_GPU_ALLOCATOR=cuda_malloc_async
to the environment variables to see if it would fix it. I didn’t get an OOM error like last time, but it also terminated the program:
Microsoft Windows [Version 10.0.19043.1288]
(c) Microsoft Corporation. All rights reserved.
C:\Users\"username">cd C:\Users\"username"\Desktop\gpt-2-finetuning\src
C:\Users\"username"\Desktop\gpt-2-finetuning\src>python generate_unconditional_samples.py --model_name novel
2021-10-17 15:20:12.172740: I tensorflow/core/platform/cpu_feature_guard.cc:142] This TensorFlow binary is optimized with oneAPI Deep Neural Network Library (oneDNN) to use the following CPU instructions in performance-critical operations: AVX AVX2
To enable them in other operations, rebuild TensorFlow with the appropriate compiler flags.
2021-10-17 15:20:12.681534: I tensorflow/core/common_runtime/gpu/gpu_process_state.cc:215] Using CUDA malloc Async allocator for GPU: 0
What exactly is going on here? Why would cudnn be eating up my GPU like this?
