My program is terminating with the following Application Error.
The application failed to initialize properly (0xc0000005). Click on OK to terminate the application.
I think that this has something to do with CUDPP. Any suggestions or thoughts would be appreciated.
the following is my scan.cu file that I am linking to from my main file.
#include <cutil.h>
#include <cutil_math.h>
#include <cudpp/cudpp.h>
#include <stdio.h>
#include <math.h>
#include <string.h>
#include <float.h>
extern "C" void run_scan(void);
extern "C" void computSumScanGold( float* reference, float* h_idata, int
numElements, CUDPPConfiguration config);
void run_scan(void)
printf("initializing CUDA\n");
CUT_DEVICE_INIT(0, &"");
unsigned int numElements = 32768;
unsigned int memSize = sizeof(float) * numElements;
printf("allocating memory\n");
float* h_idata = (float*) malloc(memSize);
for(unsigned int i = 0; i < numElements; ++i)
h_idata[i] = (float) (rand() & 0xf);
float* d_idata;
CUDA_SAFE_CALL( cudaMalloc( (void**) &d_idata, memSize) );
CUDA_SAFE_CALL( cudaMemcpy( d_idata,
h_idata,
memSize,
cudaMemcpyHostToDevice) );
float* d_odata;
CUDA_SAFE_CALL( cudaMalloc( (void**) &d_odata,
memSize) );
printf("initializing CUDPP\n");
CUDPPConfiguration config;
config.op = CUDPP_ADD;
config.datatype = CUDPP_FLOAT;
config.algorithm = CUDPP_SCAN;
config.options =
CUDPP_OPTION_FORWARD | CUDPP_OPTION_EXCLUSIVE;
CUDPPHandle scanplan = 0;
CUDPPResult result = cudppPlan(&scanplan, config, numElements, 1, 0);
if(CUDPP_SUCCESS != result)
printf("error creating CUDPPPlan\n");
return;
printf("executing\n");
cudppScan(scanplan, d_odata, d_idata, numElements);
float* h_odata = (float*) malloc(memSize);
CUDA_SAFE_CALL( cudaMemcpy( h_odata,
d_odata,
memSize,
cudaMemcpyDeviceToHost) );
float* reference = (float*) malloc(memSize);
printf("computing reference\n");
computSumScanGold( reference, h_idata, numElements, config);
CUTBoolean res = cutComparef( reference, h_odata, numElements);
printf( "Test %s\n", (1 == res) ? "PASSED" : "FAILED");
printf("freeing memory\n");
cudaFree(d_idata);
cudaFree(d_odata);
return;
float* h_idata, int numElements, CUDPPConfiguration config)
reference[0] = 0;
for(unsigned int i = 1; i < numElements; ++i)
reference[i] = h_idata[i - 1] + reference[i - 1];
return;
