If I use cudppScan with op = CUDPP_MAX, I can get the max value of the array, but how can I get its index?
Thank you,
Thank you,
Thank you,
Hi
I do not quite understand your question. Can you state more precise what you want?
Hi
If I use cudppScan to do a scan to find the max value of an array, I can get the max value of this array which is the last value of the result array. But I still do not know the index of the max element of this array.
Example code:
CUDPPConfiguration config;
config.op = CUDPP_MAX;
config.datatype = CUDPP_FLOAT;
config.algorithm = CUDPP_SCAN;
config.options = CUDPP_OPTION_FORWARD | CUDPP_OPTION_EXCLUSIVE;
CUDPPHandle scanplan = 0;
CUDPPResult result = cudppPlan(&scanplan, config, numElements, 1, 0);
// Run the scan
cudppScan(scanplan, d_odata, d_idata, numElements);
// now the max value is in d_odata[numElements - 1], but what is the index for it?
Example code:
// Run the scan
