[CUF] cuda-aware mpi send/recv segfault with cuda-memcheck
I’m trying to exchange device data between two process on the same node.
Here my my code :
program main
	use mpi
	implicit none
	integer :: rank, ierr, tmp2
	integer,dimension(MPI_STATUS_SIZE) :: status
	integer,device,allocatable :: tmp(:)
	call mpi_init(ierr)
  allocate(tmp(1))
  tmp=0
  call mpi_comm_rank(MPI_COMM_WORLD, rank, ierr)
  if (rank .eq. 0) then
     tmp(1) = 56
     call mpi_send(tmp,1,MPI_INT,1,42,MPI_COMM_WORLD,ierr)
  end if
  if (rank .eq. 1) then
     call mpi_recv(tmp,1,MPI_INT,0,42,MPI_COMM_WORLD,status,ierr)
     tmp2 = tmp(1)
     print *, tmp2
  end if
	call mpi_finalize(ierr)
end program main
Compiled with :
mpif90 -Mcuda -g -O3 bug.f90 -o bug
$ompi_info --version
Open MPI v2.1.2
$ompi_info --parsable --all | grep mpi_built_with_cuda_support:value
mca:mpi:base:param:mpi_built_with_cuda_support:value:true
$mpif90 --version
pgfortran 18.4-0 64-bit target on x86-64 Linux -tp haswell
$cuda-memcheck --version
CUDA-MEMCHECK version 10.0.130 ID:(46)
Here is what happens when I run the code :
$mpirun -np 2 ./bug
56
$mpirun -np 1 cuda-memcheck ./bug : -np 1 ./bug
[:23497] *** Process received signal ***
[:23497] Signal: Segmentation fault (11)
[:23497] Signal code: Address not mapped (1)
[:23497] Failing at address: 0x198
========= Error: process didn’t terminate successfully
========= The application may have hit an error when dereferencing Unified Memory from the host. Please rerun the application under cuda-gdb or Nsight Eclipse Edition to catch host side errors.
========= No CUDA-MEMCHECK results found
Primary job terminated normally, but 1 process returned
a non-zero exit code… Per user-direction, the job has been aborted.
mpirun detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
Process name: [[32240,1],0]
Exit code: 1
I know there is no reason to call cuda-memcheck here, but my real code is obviously composed of cuda kernels. When running with cuda-gdb with set cuda memcheck on, no issue arises. Am I missing something obvious here? Thanks.
Hi dindon,
I think the problem here is that your program requires 2 ranks and will error with 1 rank.
% mpirun -np 1 bug
[sky4:199439] *** An error occurred in MPI_Send
[sky4:199439] *** reported by process [140730681065473,47304769798144]
[sky4:199439] *** on communicator MPI_COMM_WORLD
[sky4:199439] *** MPI_ERR_RANK: invalid rank
[sky4:199439] *** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort,
[sky4:199439] ***    and potentially your MPI job)
% mpirun -np 2 cuda-memcheck bug
========= CUDA-MEMCHECK
           56
========= ERROR SUMMARY: 0 errors
Hope this helps,
Mat
Hi Mat,
In the command I use to run my program, one process is calling ‘./bug’ while the other is calling ‘cuda-memcheck ./bug’ (two process in total) :
I could have run for the same effect :
$mpirun -np 2 cuda-memcheck ./bug
Apologies that I missed that, though, the program still works for me.
% mpirun -np 1 cuda-memcheck ./bug : -np 1 ./bug
56
I’m using OpenMPI on a Linux system with a V100.
Which MPI are you using? What is the output on the command ‘pgaccelinfo’?
-Mat
I’m using OpenMPI 2.1.2 (shipped with PGI 18.4)
$ pgaccelinfo
CUDA Driver Version: 10000
NVRM version: NVIDIA UNIX x86_64 Kernel Module 410.57 Tue Sep 18 23:25:09 CDT 2018
Device Number: 0
Device Name: GeForce GTX 1070
Device Revision Number: 6.1
Global Memory Size: 8513978368
Number of Multiprocessors: 15
Concurrent Copy and Execution: Yes
Total Constant Memory: 65536
Total Shared Memory per Block: 49152
Registers per Block: 65536
Warp Size: 32
Maximum Threads per Block: 1024
Maximum Block Dimensions: 1024, 1024, 64
Maximum Grid Dimensions: 2147483647 x 65535 x 65535
Maximum Memory Pitch: 2147483647B
Texture Alignment: 512B
Clock Rate: 1784 MHz
Execution Timeout: No
Integrated Device: No
Can Map Host Memory: Yes
Compute Mode: default
Concurrent Kernels: Yes
ECC Enabled: No
Memory Clock Rate: 4004 MHz
Memory Bus Width: 256 bits
L2 Cache Size: 2097152 bytes
Max Threads Per SMP: 2048
Async Engines: 2
Unified Addressing: Yes
Managed Memory: Yes
Concurrent Managed Memory: Yes
Preemption Supported: Yes
Cooperative Launch: Yes
Multi-Device: Yes
PGI Compiler Option: -ta=tesla:cc60
Just gave the code a try on a GTX 1070 here using PGI 18.4 and the OpenMPI that ships with the 18.4 compilers. For good or bad, it still works for me. Though, I only have a CUDA 8.0 driver on this system.
I’m guessing that it’s something to do with your system such as a mismatch between the cuda-memcheck version and your CUDA driver version.
Looks like you’re using a CUDA 10.0 driver. Which version of cuda-memcheck are you using? Can you try getting the CUDA 10.0 SDK and seeing if that version fixes the problem?
-Mat
You’re right. I used cuda-memcheck (from CUDA toolkit 10) while the code was running with the CUDA 8 libraries.
My pgi install isn’t shipped with CUDA 10 and I couldn’t make it use my own installation of CUDA 10, but after getting cuda-memcheck from the CUDA toolkit 8, the code works.
Thanks Mat.
Hi dindon,
Starting with 18.4, you can set the environment variable “CUDA_HOME” to your CUDA installation to have the compiler use this version. Just don’t include the CUDA version option to the compiler flags “-ta” or “-Mcuda” since this overrides this.
Granted CUDA 10.0 came out six months after PGI 18.4 so there may be other issues, but you can give this a try as well.
-Mat
