I am trying to explore the cuf syntax directive for my code. Since, I had problems using do(2) directive I prepared this test case (the meaning of operations is not important) which does not work. Can anybody help me?
module storage
integer, parameter :: N=10
real :: a(N,N),b(N,N)
real, device :: a_dev(N,N),b_dev(N,N)
end module storage
program cuf_fail
use storage
implicit none
integer i,j
a = 1. ;
a_dev = a ;
!$cuf kernel do(2) <<<*,*>>>
do i=2,N-1
do j=1,N
b_dev(i,j) = a_dev(i+1,j) -2.*a_dev(i,j) + a_dev(i-1,j)
enddo
enddo
b = b_dev
print*,'b: ',b
end
The compiling error is
PGF90-S-0000-Internal compiler error. incompletely-translated array bound 1 (cuf_fail.f90: 25)
PGF90-S-0000-Internal compiler error. load of zero symbol 0 (cuf_fail.f90: 25)
0 inform, 0 warnings, 8 severes, 0 fatal for cuf_fail
The error occurs only using variables stored in module structure. I am using 11.3 version of PGI.
thanks in advance
Francesco
