cufft_c2c_radix4?
Has anyone had luck calling the cufft_c2c_radix4 kernel from the NVIDIA_CUFFT_1.1.zip source posted a few weeks ago? For instance, if I try to compute 512, 1024-point FFTs like this:
    cufftStride inStride;
    inStride.ibStride = 1024;
    inStride.ieStride = 1;
    inStride.obStride = 1024;
    inStride.oeStride = 1;
    cufft_c2c_radix4<<<512,1024/4,1024*sizeof(cData)>>>(1024, TP/1024.0, 10, inbuf, outbuf, -1, inStride);
only the ‘even’ samples in outbuf appear to be correct. Has anyone else noticed this? I tried it both on an 8600 and a C870, with the same results. Thanks,
Kalle
I just figured out what was wrong today. Look for the following line in the radix4 code.
c = base - 1;
Change it to
c = base - 2;
That is right !
Thank you,
Petru
Can someone post the full code for this, i am new to cuda and am trying to do similar using the cufft_c2c_radix2, but i cant seem to get the memory set up right?
Cheers
