CUFFT - CUFFT_SHUTDOWN_FAILED
Hi
The CUDA CUFFT Library pdf Pg-00000-003_V2.0 April 2008 states on p2:
“CUFFT_SHUTDOWN_FAILED The CUFFT library failed to shut down.”
However, if I setup an if-else block to catch all cufftResult values:
else if (result == CUFFT_SHUTDOWN_FAILED)
the compiler complains:
“error: identifier “CUFFT_SHUTDOWN_FAILED” is undefined”
Am I doing something wrong is or this a known error?
Cheers
Graham
