cuFFT + Fortran worksize definition?
I have a very simple Fortran + openACC code that performs a 3D FFT of a 3D matrix (n x n x n).
In the new plan subroutines (cuFFTmakePlan3D) there is an additional argument (int_t *worksize).
How should be this pointer be defined? I tried as c_ptr but it does not seem to work.
Using the old cuFFTPlan3D (which I guess will be soon deprecated) everything works because this additional argument is not present.
It is an integer(8). FYI, the interfaces are documented here:
https://docs.nvidia.com/hpc-sdk/compilers/fortran-cuda-interfaces/index.html#fft-cufftmakeplan3d
Thanks bleback for the clarification and the link.
Now it works.
