Cufft idist and odist not working as expected
I have a ragged array with multiple shaped 1D sequences
I am looking to make a batched 1D FFT on two 1D sequence that are contiguous but not adjacent.
        int rank = 1;         // 1D FFT
        int batch_size = 2;   // Number of rings to transform
        int n[] = {size};     // Size of each FFT
        int *inembed = NULL;  // Stride of input data
        int istride = 1;      // Distance between consecutive elements in the same batch
        int idist = 188;  // Distance between the starting points of two consecutive batches
        int *onembed = NULL;            // Stride of output data
        int ostride = 1;                // Distance between consecutive elements in the same batch
        int odist = 188;
        std::cout << "For ring " << i << " size is " << size << " dist is " << dist << std::endl;
        CUFFT_CALL(cufftMakePlanMany(plan, rank, n, inembed, istride, idist, onembed, ostride, odist,
                                     CUFFT_C2C, batch_size, &polar_worksize));
The size if 4 and the idist = odist is 188
Yet when I execute the plan, the first 8 elements are transformed, instead of the first 4 and the last 4 of my array.
Anyone have an idea how can I use this from the documentation :
1D
input[ b * idist + x * istride ]
output[ b * odist + x * ostride ]
Thank you
The solution is to set inembed and onembed to anything which is a bit counter intuitive for a 1D transform
You might get better help with a short, complete example. You may wish to review the advanced data layout section of the cufft docs. which states:
Passing inembed or onembed set to NULL is a special case and is equivalent to passing n for each. This is same as the basic data layout and other advanced parameters such as istride are ignored.
