# cuFFT Performance for increasing array sizes
**URL:** <https://forums.developer.nvidia.com/t/cufft-performance-for-increasing-array-sizes/107737>\
**Category:** GPU-Accelerated Libraries\
**Created:** [November 20, 2019, 1:58pm UTC](https://forums.developer.nvidia.com/t/cufft-performance-for-increasing-array-sizes/107737 "2019-11-20T13:58:08Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![rhaney](https://developer.download.nvidia.com/images/forums/profile-default-devtalk-84.png) [@rhaney](https://forums.developer.nvidia.com/u/rhaney)\
**Post date:** [November 20, 2019, 1:58pm UTC](https://forums.developer.nvidia.com/t/cufft-performance-for-increasing-array-sizes/107737/1 "2019-11-20T13:58:08Z")
</div>
Please help,
First of all, I apologize for re-posting this question from another section of forums - I think the question might be better asked here. I will properly place my question(s) next time.
I have a performance question regarding cuFFT using Complex-to-Complex forward FFT on 1D array - no errors or unexpected data, just performance question.
The observed performance for cuFFT forward FFT drops significantly when the array length is 2_2,097,157 (4,194,314), while array sizes 2_1,048,576 (2,097,152) and 2\*4,194,304 (8,388,608) perform as expected. Is this an issue with FFT in general, an artifact of the employed algorithms of FFT?
example timing where array size is N:
N – DEVICE Time (ms.)
2,097,152 – 0.96
4,194,314 – 253.50
8,388,608 – 2.15
I am using a single GPU (Titan V) with compute architecture 10.1. A sample of the code I am using follows:
```auto
#include <cufft.h>
#include <stdio.h>
// I left off CUDA timing and error handling as I just want to
// know if there is something I am doing wrong with calling the
// cuFFT library
int main(){
  // length of array - when N is 2097157 the performance is
  // significantly worse than either 1048576 or 4194304
  const unsigned int N = 2097157;
  cuComplex *darray, *harray, *result;
  harray = (cuComplex*)malloc(2*N*sizeof(cuComplex);
  result = (cuComplex*)malloc(2*N*sizeof(cuComplex);
  cudaMalloc((void**)&darray, 2*N*sizeof(cuComplex));
  // initialize
  for(unsigned int i = 0; i < 2*N; ++i){
    harray[i].x = (float)i;
    harray[i].y = 1.0f;
  // copy to DEVICE
  cudaMemcpy(darray, harray, 2*N*sizeof(cuComplex), cudaMemcpyHostToDevice);
  // Didn't wrap these calls in error macros
  cufftHandle plan;
  cufftPlan1d(&plan, 2*N, CUFFT_C2C, 1);
  cufftExecC2C(plan, darray, darray, CUFFT_FORWARD);
  cufftDestroy(plan);
  // copy to HOST
  cudaMemcpy(result, darray, 2*N*sizeof(cuComplex), cudaMemcpyDeviceToHost);
  free(harray);
  free(result);
  cudaFree(darray);
  return 0;
Any ideas or hints as to why this behavior occurs would be great.
Thank you
**Author:** ![Robert\_Crovella](https://sea2.discourse-cdn.com/nvidia/user_avatar/forums.developer.nvidia.com/robert_crovella/32/14043_2.png) [@Robert\_Crovella](https://forums.developer.nvidia.com/u/Robert_Crovella)\
**Post date:** [November 20, 2019, 3:18pm UTC](https://forums.developer.nvidia.com/t/cufft-performance-for-increasing-array-sizes/107737/2 "2019-11-20T15:18:18Z")
</div>
THe CUFFT performance is sensitive to the prime factorization of the size. For example power-of-2 sizes generally perform fastest. sizes that contain large prime factors may perform much slower.
This is documented int the CUFFT docs.
considering this:
2,097,152 – power of 2
4,194,314 – not a power of 2
8,388,608 – power of 2
if you change 4194314 to 4194304, you will see the performance drop in line with expectations (slower than 2097152, faster than 8388608)
**Post date:** [November 20, 2019, 3:27pm UTC](https://forums.developer.nvidia.com/t/cufft-performance-for-increasing-array-sizes/107737/3 "2019-11-20T15:27:21Z")
</div>
Thank you for information.
