Greetings,
I’ve one problem with che cufft library:
when i calculate 1d transform Real-to-Complex of an array of 500 elements
the function returns an array where the first 251 positions are the coefficients and the other 249 are ‘nan’-
this because (i suppose) the transform of a real function is simmetric, so i can calculate the 249 missing elements simply copying
the complex coniugate of the first 250 elements.
here the question:
in which position is the freq 0 in the array that the function returns? 0 or 251?
Here’s a crazy idea: give as input a DC signal. Examine output for non-zero values.
Good Idea!
i tried with a box function:
cufftReal box[] = {0.0,0.0,0.0,0.0,0.0,0.0,0.0,1.0,1.0,1.0,0.0,0.0,0.0,0.0,0.0
,0.0,0.0};
and the output is:
tra[0].x: 3.000000 tra[0].y: 0.000000
tra[1].x: -2.816163 tra[1].y: -0.526432
tra[2].x: 2.310682 tra[2].y: 0.895164
tra[3].x: -1.608166 tra[3].y: -0.995735
tra[4].x: 0.875383 tra[4].y: 0.798018
tra[5].x: -0.272797 tra[5].y: -0.361242
tra[6].x: -0.091496 tra[6].y: -0.183749
tra[7].x: 0.191684 tra[7].y: 0.673696
tra[8].x: -0.089125 tra[8].y: -0.961825
tra[9].x: -nan tra[9].y: -nan
tra[10].x: -nan tra[10].y: -nan
tra[11].x: -nan tra[11].y: -168810647249264880326041152057895813120.000000
tra[12].x: -nan tra[12].y: -1.873534
tra[13].x: -nan tra[13].y: -nan
tra[14].x: 170141153036854826254181667795007176704.000000 tra[14].y: -31127745928385003520.000000
tra[15].x: -nan tra[15].y: -nan
tra[16].x: -158446644177238792414399823872.000000 tra[16].y: -2417556347208890920730624.000000
tra.x is the real part of the transform and tra.y is the imaginary part…
so the freq 0 is stored in pos 0 ( [3] + [0]i ).
