I am using CUDA’s Cufft to process data i receive from a hydrophone(500,000 integers a second at 250hertz). Now as a basic example of how Cufft works is here…
void runTest(int argc, char** argv)
printf("[1DCUFFT] is starting...\n");
cufftComplex* h_signal = (cufftComplex*)malloc(sizeof(cufftComplex)* SIGNAL_SIZE);
// Allocate host memory for the signal
//Complex* h_signal = (Complex*)malloc(sizeof(Complex) * SIGNAL_SIZE);
// Initalize the memory for the signal
for (unsigned int i = 0; i < SIGNAL_SIZE; ++i) {
h_signal[i].x = rand() / (float)RAND_MAX;
h_signal[i].y = 0;
int mem_size = sizeof(cufftComplex)* SIGNAL_SIZE;
// Allocate device memory for signal
cufftComplex* d_signal;
cudaMalloc((void**)&d_signal, mem_size);
// Copy host memory to device
cudaMemcpy(d_signal, h_signal, mem_size,
cudaMemcpyHostToDevice);
// CUFFT plan
cufftHandle plan;
cufftPlan1d(&plan, mem_size, CUFFT_C2C, 1);
// Transform signal
printf("Transforming signal cufftExecC2C\n");
cufftExecC2C(plan, (cufftComplex *)d_signal, (cufftComplex *)d_signal, CUFFT_FORWARD);
// Transform signal back
printf("Transforming signal back cufftExecC2C\n");
cufftExecC2C(plan, (cufftComplex *)d_signal, (cufftComplex *)d_signal, CUFFT_INVERSE);
// Copy device memory to host
cufftComplex* h_inverse_signal = (cufftComplex*)malloc(sizeof(cufftComplex)* SIGNAL_SIZE);;
cudaMemcpy(h_inverse_signal, d_signal, mem_size,
cudaMemcpyDeviceToHost);
for (int i = 0; i < SIGNAL_SIZE; i++){
h_inverse_signal[i].x = h_inverse_signal[i].x / (float)SIGNAL_SIZE;
h_inverse_signal[i].y = h_inverse_signal[i].y / (float)SIGNAL_SIZE;
printf("first : %f %f after %f %f \n", h_signal[i].x, h_signal[i].y, h_inverse_signal[i].x, h_inverse_signal[i].y);
//Destroy CUFFT context
cufftDestroy(plan);
// cleanup memory
free(h_signal);
free(h_inverse_signal);
cudaFree(d_signal);
cudaDeviceReset();
Now all I want to know is, how do i set the frequency of the FFT to be 250hertz?
James
