cufftPlan1d() overhead
real time signal data analysis .
this is my code
int mem_size = sizeof(Complex) * SIGNAL_SIZE;
  // Allocate device memory for signal
   Complex* d_signal;
   CUDA_SAFE_CALL(cudaMalloc((void**)&d_signal, mem_size));
   // Copy host memory to device
   CUDA_SAFE_CALL(cudaMemcpy(d_signal, h_signal, mem_size,
                             cudaMemcpyHostToDevice));
     cufftPlan1d(&plan, ??, CUFFT_DATA_C2C, 1);
// Transform signal and kernel
 CUFFT_SAFE_CALL(cufftExecute(plan, d_signal, d_signal, CUFFT_FORWARD));
 CUFFT_SAFE_CALL(cufftExecute(plan, d_signal, d_signal, CUFFT_INVERSE));
   // Copy device memory to host
   Complex* h_result_signal = h_signal;
   CUDA_SAFE_CALL(cudaMemcpy(h_result_signal, d_signal, mem_size,
                             cudaMemcpyDeviceToHost));
real time input signal data
#define  SMPRATE        	44100
#define  BUFSIZE        	16384
	wfx.wFormatTag = WAVE_FORMAT_PCM;	// PCM format
  	wfx.nChannels = 1;    	// mono sound
  	wfx.nSamplesPerSec = SMPRATE;  // sampling rate
  	wfx.nAvgBytesPerSec = SMPRATE*2;	// 16 bytes per sample
  	wfx.nBlockAlign = 2;    // bytes per sample
  	wfx.wBitsPerSample = 16;  	// bits per sample
  	wfx.cbSize = 0;      // extra info (ignored for PCM)
what is plan fuction paramera ??
16?
16384?
too many overhead…
