I have implemented the case from the ProTip: CUDA Pro Tip: Use cuFFT Callbacks for Custom Data Processing | NVIDIA Technical Blog
Using the code found here:
https://github.com/NVIDIA-developer-blog/code-samples/blob/master/posts/cufft-callbacks/cufft_callbacks.cu
I compiled and linked the code as was recommended:
nvcc -dc -c cufft_callbacks.cu -o cufft_callbacks.o
nvcc -o cufft_callbacks cufft_callbacks.o -lcufft -lcufft_static -lculibos
But I get CUFFT_NOT_IMPLEMENTED from the cufftXtSetCallback when running:
Preparing input: 1000x1024
Computing reference solution
Creating FFT plan
CUDA error at cufft_callbacks.cu:121 code=14 “status”
This is the same error I am getting from a separate test I was doing, so I doubt the issue is the code itself. I should be running on 64-bit OS, using CUDA compute 7.5 and nvvc version 11.6.
