cuGraphicsGLRegisterBuffer failed with error(219) gst_eglglessink_cuda_init texture = 1 on A10 dGPU
A10 on x86
• DeepStream Version
6.1
• TensorRT Version
8.4.3.1-1+cuda11.6
Driver Version: 515.65.01
question
When running deepstream app on A10 card with sink enable , seeing following above error
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=1
source-id=0
gpu-id=0
nvbuf-memory-type=0
In one of the forum post (cuGraphicsGLRegisterBuffer failed with error(219) gst_eglglessink_cuda_init texture = 1), it is mentioned that the display will on work for Tesla or if the gpu is a compute card, is it valid for A10?.
If not what package am I missing here?
A10 is tesla card. You can follow this if you need display, Deepstream/FAQ - eLinux.org 5A
other options, if you do not need display, you can choose type 1, if you need the output to view, you can choose type 3 file, save to file. or 4, rtspstreaming, view it by vlc.
