• Hardware Platform (Jetson / GPU) nvidia-smi
Tue Dec 20 09:32:39 2022
| NVIDIA-SMI 510.108.03 Driver Version: 510.108.03 CUDA Version: 11.7 |
| | | MIG M. |
| 0 Tesla V100-PCIE… Off | 00000000:65:00.0 Off | 0 |
| N/A 53C P0 28W / 250W | 48MiB / 16384MiB | 2% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
• DeepStream Version Docker
• TensorRT Version Docker
**• How to reproduce the issue ?
xhost +
docker run --gpus all -it --rm --net=host --privileged -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY -w /opt/nvidia/deepstream/deepstream-6.1 nvcr.io/nvidia/deepstream:6.1.1-samples
cd samples/configs/deepstream-app
deepstream-app -c source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
after this Get below error…
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin3/GstURIDecodeBin:src_elem
WARNING from src_elem: No decoder available for type ‘audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)119056e500, rate=(int)48000, channels=(int)2’.
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin1/GstURIDecodeBin:src_elem
cuGraphicsGLRegisterBuffer failed with error(219) gst_eglglessink_cuda_init texture = 1
** INFO: <bus_callback:180>: Pipeline running
**PERF: FPS 0 (Avg) FPS 1 (Avg) FPS 2 (Avg) FPS 3 (Avg)
**PERF: 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00)
**PERF: 398.37 (1.06) 398.37 (1.06) 398.37 (1.06) 398.37 (1.06)
**PERF: 0.00 (0.52) 0.00 (0.52) 0.00 (0.52) 0.00 (0.52)
ERROR from secondary_gie_bin_queue: Internal data stream error.
Debug info: gstqueue.c(988): gst_queue_handle_sink_event (): /GstPipeline:pipeline/GstBin:secondary_gie_bin/GstQueue:secondary_gie_bin_queue:
streaming stopped, reason not-negotiated (-4)
Quitting
ERROR from sink_bin_queue: Internal data stream error.
Debug info: gstqueue.c(988): gst_queue_handle_sink_event (): /GstPipeline:pipeline/GstBin:processing_bin_0/GstBin:sink_bin/GstQueue:sink_bin_queue:
[NvMultiObjectTracker] De-initialized
to give more information in advance: I already have connected a physical display currently using by taking remote access.
