TL;DR
Argus
providescuEGLStream
- To access
cuEGLFrame
,cuGraphicsResourceGetMappedEglFrame()
is necessary - However, it maps to the host and device memory (not always to the device memory)
- (RAW16 maps to the device, YCrCb maps to the CPU)
Hello!
I use Argus
to retrieve camera frame via EGLStream
, and it is then processed with OpenCV
To take full advantage of GPU, I’m currently working on cuEGLStream
so that I can directly connect to cv::cuda::GpuMat
Meanwhile, I’ve found something unexpected.
argus/samples/syncSensor
demonstrates how to use cuEGLStream
with Argus
For EGLStream, it uses PIXEL_FMT_YCbCr_420_888
: m_connection(connection), m_stream(NULL), m_resource(0)
CUresult r = cuEGLStreamConsumerAcquireFrame(&m_connection, &m_resource, &m_stream, -1);
if (r == CUDA_SUCCESS)
r = cuGraphicsResourceGetMappedEglFrame(&m_frame, m_resource, 0, 0);
uchar* ptr = (uchar*) m_frame.frame.pPitch[0];
// In theory, it should throw Segfault since ptr is pointing the device memory
for (int i = 0; i < 10; i++)
printf("%u ",ptr[i]);
printf("\n");
The above code actually prints values and terminates without any error.
However, if I change the pixel forma to PIXEL_FMT_RAW16
, the code stuck at cuEGLStreamConsumerAcquireFrame()
Also, I tried NvCvCam which uses PIXEL_FMT_RAW16
for EGLStream
In frame.cpp
you can find a snippet where acquiring and mapping are done to convert cuEGLFrame
into cv::cuda::GpuMat
Frame::Frame(CUgraphicsResource resource,
CUeglStreamConnection conn,
cudaStream_t stream)
: _resource(resource), _conn(conn), _stream(stream), _raw_frame(), _mat() {
CUresult cu_err;
DEBUG << "frame:Mapping from resource.";
cu_err = cuGraphicsResourceGetMappedEglFrame(&_raw_frame, resource, 0, 0);
if (cu_err) {
ERROR << "frame:Could not map CUgraphicsResource to CUeglFrame becuase: "
<< error_string(cu_err) << ".";
return;
if (_raw_frame.width > std::numeric_limits<int>::max()) {
ERROR << "_raw_frame.width out of range: " << _raw_frame.width;
std::terminate();
if (_raw_frame.height > std::numeric_limits<int>::max()) {
ERROR << "_raw_frame.height out of range: " << _raw_frame.height;
std::terminate();
if (!utils::printCUDAEGLFrame(_raw_frame)) {
return;
uchar* ptr = (uchar*) _raw_frame.frame.pPitch[0];
// When PIXEL_FMT_YCbCr_420_888, it prints
// When RAW16, throws Segfault (illegal memory access)
printf("\n");
// map the data to a GpuMat
_mat = cv::cuda::GpuMat(_raw_frame.height, _raw_frame.width, CV_16UC1,
_raw_frame.frame.pPitch[0], _raw_frame.pitch);
Conclusion
My conclusion is, when using YCrCb
, it maps to CPU
Unfortunately, I want it to be GPU
, a device memory.
Any help will be appreciated!
syncSensor.zip (11.0 KB)
