I am trying to compile this benchmark:
https://github.com/pathscale/rodinia/blob/master/openacc/bfs/bfs.cpp
I list my slightly modified version (I have added some print statements) at the end of the post. When I try to run the benchmark, I get the following error:
call to cuMemcpyDtoHAsync returned error 1: Invalid value
I have tried to run this through gdb to get some better idea where does the problem occur, and this is what I get:
(gdb)
183 }
(gdb) n
So it seems that there is at least one successful iteration through the kernels.
How can I go about debugging this? What information would you need to help me?
EDIT:
I was able to compile the code with the Cray compiler that is also available on my machine (I had to remove the reduction on the stop value because of compilation errors). The generated code fails in a similar way:
CC: craylibs/libcrayacc/acc_hw_nvidia.c:560 CRAY_ACC_ERROR - cuMemcpyHtoD returned CUDA_ERROR_INVALID_VALUE from bfs.cpp:139
This leads me to believe that perhaps the benchmark uses OpenACC incorrectly. Can anybody confirm this?
Thanks,
Marcin
Here is the code:
#include <stdio.h>
#include <string.h>
#include <math.h>
#include <stdlib.h>
#define TRANSFER_GRAPH_NODE 1
int no_of_nodes;
int edge_list_size;
FILE *fp;
//Structure to hold a node information
struct Node
int starting;
int no_of_edges;
void BFSGraph(int argc, char** argv);
void Usage(int argc, char**argv){
fprintf(stderr,"Usage: %s <input_file>\n", argv[0]);
// Main Program
int main( int argc, char** argv)
no_of_nodes=0;
edge_list_size=0;
BFSGraph( argc, argv);
//Apply BFS on a Graph using CUDA
void BFSGraph( int argc, char** argv)
char *input_f;
int* h_cost;
int* h_graph_edges;
if(argc!=2){
Usage(argc, argv);
exit(0);
input_f = argv[1];
printf("Reading File\n");
//Read in Graph from a file
fp = fopen(input_f,"r");
if(!fp)
printf("Error Reading graph file\n");
return;
int source = 0;
fscanf(fp,"%d",&no_of_nodes);
printf("Number of nodes: %d\n", no_of_nodes);
// allocate host memory
Node* h_graph_nodes = (Node*) malloc(sizeof(Node)*no_of_nodes);
bool *h_graph_mask = (bool*) malloc(sizeof(bool)*no_of_nodes);
bool *h_updating_graph_mask = (bool*) malloc(sizeof(bool)*no_of_nodes);
bool *h_graph_visited = (bool*) malloc(sizeof(bool)*no_of_nodes);
printf("Reading nodes: ");
int start, edgeno;
// initalize the memory
for( unsigned int i = 0; i < no_of_nodes; i++)
fscanf(fp,"%d %d",&start,&edgeno);
h_graph_nodes[i].starting = start;
h_graph_nodes[i].no_of_edges = edgeno;
if(i % 100 == 0) printf(".");
printf("\n");
//read the source node from the file
fscanf(fp,"%d",&source);
source=0;
printf("Source vertex: %d\n", source);
#pragma acc data create(h_updating_graph_mask[0:no_of_nodes]) \
create(h_graph_mask[0:no_of_nodes],h_graph_visited[0:no_of_nodes]) \
create(h_graph_nodes[0:no_of_nodes], h_graph_edges[0:edge_list_size]) \
copyout(h_cost[0:no_of_nodes])
//printf("In the acc scope.\n");
#pragma acc update device(h_graph_nodes[0:no_of_nodes]) async(TRANSFER_GRAPH_NODE)
#pragma acc parallel loop
//printf("Processing node %d", i);
h_updating_graph_mask[i]=false;
h_graph_mask[i]=false;
h_graph_visited[i]=false;
#pragma acc kernels present(h_graph_mask[0:no_of_nodes],h_graph_visited[0:no_of_nodes])
//set the source node as true in the mask
h_graph_mask[source]=true;
h_graph_visited[source]=true;
fscanf(fp,"%d",&edge_list_size);
int id,cost;
h_graph_edges = (int*) malloc(sizeof(int)*edge_list_size);
for(int i=0; i < edge_list_size ; i++)
fscanf(fp,"%d",&id);
fscanf(fp,"%d",&cost);
h_graph_edges[i] = id;
if(fp)
fclose(fp);
// allocate mem for the result on host side
h_cost = (int*) malloc( sizeof(int)*no_of_nodes);
for(int i=0;i<no_of_nodes;i++) {
h_cost[i]=-1;
if(i == source) h_cost[source]=0;
// finish transfer node and edge to target
#pragma acc update device(h_graph_edges[0:edge_list_size])
#pragma acc wait(TRANSFER_GRAPH_NODE)
printf("Start traversing the tree\n");
int k=0;
bool stop;
do
//if no thread changes this value then the loop stops
stop=false;
for(int tid = 0; tid < no_of_nodes; tid++ )
if (h_graph_mask[tid] == true){
h_graph_mask[tid]=false;
for(int i=h_graph_nodes[tid].starting; i<(h_graph_nodes[tid].no_of_edges + h_graph_nodes[tid].starting); i++)
int id = h_graph_edges[i];
if(!h_graph_visited[id])
h_cost[id]=h_cost[tid]+1;
h_updating_graph_mask[id]=true;
#pragma acc parallel loop vector reduction(||:stop)
for(int tid=0; tid< no_of_nodes ; tid++ )
if (h_updating_graph_mask[tid] == true){
h_graph_mask[tid]=true;
h_graph_visited[tid]=true;
stop=true;
h_updating_graph_mask[tid]=false;
k++;
while(stop);
} /* end acc data */
//Store the result into a file
FILE *fpo = fopen("result.txt","w");
fprintf(fpo,"%d) cost:%d\n",i,h_cost[i]);
fclose(fpo);
printf("Result stored in result.txt\n");
// cleanup memory
free( h_graph_nodes);
free( h_graph_edges);
free( h_graph_mask);
free( h_updating_graph_mask);
free( h_graph_visited);
free( h_cost);
[/b]
