Cuml-cu11 install fails
hi, when trying to install cuml-cu11, I get the following error message:
Looking in indexes: https://pypi.org/simple, https://pypi.nvidia.com
Collecting cuml-cu11
  Downloading cuml-cu11-23.12.0.tar.gz (6.8 kB)
  Preparing metadata (setup.py) ... error
  error: subprocess-exited-with-error
  × python setup.py egg_info did not run successfully.
  │ exit code: 1
  ╰─> [16 lines of output]
        File "<string>", line 2, in <module>
        File "<pip-setuptools-caller>", line 34, in <module>
        File "/tmp/pip-install-vsrq46sb/cuml-cu11_d2c6bad82e3846d1aad06369f8c99ae5/setup.py", line 137, in <module>
          raise RuntimeError(open("ERROR.txt", "r").read())
      RuntimeError:
      The package you are trying to install is only a placeholder project on PyPI.org repository.
      This package is hosted on NVIDIA Python Package Index.
      This package can be installed as:
      $ pip install --no-cache-dir --extra-index-url https://pypi.nvidia.com cuml-cu11
      [end of output]
  note: This error originates from a subprocess, and is likely not a problem with pip.
error: metadata-generation-failed
× Encountered error while generating package metadata.
╰─> See above for output.
note: This is an issue with the package mentioned above, not pip.
hint: See above for details.
The error persists when using pip install --no-cache-dir --extra-index-url https://pypi.nvidia.com cuml-cu11 or when targeting specific cuml-cu11 versions. It used to work well until a few days ago. Looking for help!
the issue disappeared for a few days, but now it’s back :(
still looking for help! thanks
