Cumotion with nvoloxs distance from the objects
Hey
I have implemented cumotion and nvblox to my robot and now want to use it but when I do the planning with the cumotion it plans it so close to the nvbloxs objects that it’s not reliable what would be the easiest way to integrate a safety distance so the path planning doesn’t go so close to the nvblox voxels
Hi @isoahojesse
You can use the distance_threshold to control the collision sphere: isaac_ros_cumotion — isaac_ros_docs documentation
ROS Parameter Type Default Description
distance_threshold float 0.1 Maximum distance from a given collision sphere (in meters) at which to mask points
Best,
Raffaello
Thank you for the quick response this fixed the problem!
