Hello there~
I installed jetpack on my jetson tx2 board.
And I tried to install cunn with luarocks, the following error occured.
Could you tell me how to solve it?
Error :
[ 33%] Building NVCC (Device) object lib/THCUNN/CMakeFiles/THCUNN.dir/THCUNN_generated_PReLU.cu.o
/tmp/luarocks_cunn-scm-1-6855/cunn/lib/THCUNN/generic/PReLU.cu(138): error: too many arguments in function call
/tmp/luarocks_cunn-scm-1-6855/cunn/lib/THCUNN/generic/PReLU.cu(150): error: too many arguments in function call
/tmp/luarocks_cunn-scm-1-6855/cunn/lib/THCUNN/generic/PReLU.cu(151): error: too many arguments in function call
9 errors detected in the compilation of “/tmp/tmpxft_0000130d_00000000-7_PReLU.cpp1.ii”.
CMake Error at THCUNN_generated_PReLU.cu.o.cmake:267 (message):
Error generating file
/tmp/luarocks_cunn-scm-1-6855/cunn/build/lib/THCUNN/CMakeFiles/THCUNN.dir//./THCUNN_generated_PReLU.cu.o
lib/THCUNN/CMakeFiles/THCUNN.dir/build.make:203: recipe for target ‘lib/THCUNN/CMakeFiles/THCUNN.dir/THCUNN_generated_PReLU.cu.o’ failed
make[2]: *** [lib/THCUNN/CMakeFiles/THCUNN.dir/THCUNN_generated_PReLU.cu.o] Error 1
make[2]: *** Waiting for unfinished jobs…
CMakeFiles/Makefile2:103: recipe for target ‘lib/THCUNN/CMakeFiles/THCUNN.dir/all’ failed
make[1]: *** [lib/THCUNN/CMakeFiles/THCUNN.dir/all] Error 2
Makefile:127: recipe for target ‘all’ failed
make: *** [all] Error 2
