cuPHY Performance Test Results Differ from User Guide (F08 4T4R, 14 Cells)
We are runing cuPHY Performance TestCases(F08 4T4R) now.
We follow the user guide to config a case inculding PDSCH(4 streams)/PDCCH/PUSCH(2 streams)/PUCCH/CSI-RS/SSB/PRACH, no SRS.
In the test,we add the cell number one by one, the process time threshhold(UL 1500us,DL375us as default) wasn’t broken through until 14 cells.
But in the user guide, it says: A100X supports 5 4T4R peak cells.
Why is there a big difference between our test and the user guide? Do we miss something?
The test runs on following system:
Hardareware: X86 Server( Intel Xeon W-3175X CPU) + A100 GPU + Mellanox MCX653105A-HDAT VPI adapter card
Software: Aerial CUDA-Accelerated RAN Release 24-3
Hi @fltang,
We have not benchmarked 24-3 release with A100X or A100.
Can you please share the link to this information in the user guide?
Thank you,
Balkan
we find following description in 24-2.1 Page69, but it’s gone in 24-3.
Then, can we use A100 to run cuBB Version 24-3? We have run some cuPHY cases, it still works
By the way, when we run cuPHY cases, we find the tensor core usage is less than 1%.
Is it normal? Why cuPHY doesn’t use tensor core to accelerate?
