Here’s a complete reproducer if you’re interested
#include <cuda.h>
#include <cuda_runtime.h>
#include <cupti.h>
#include <cstdio>
#include <cstdlib>
#include <cstring>
#include <mutex>
#include <utility>
#include <vector>
#define CHECK(call) \
do { \
auto status = (call); \
if (status != 0) { \
std::fprintf(stderr, "%s failed: %d\n", #call, int(status)); \
return 1; \
} while (0)
extern "C" __global__ void kernel(float *output, int iterations) {
float value = threadIdx.x;
for (int i = 0; i < iterations; ++i)
value = value * 1.0000001192092896f + 0.0000001192092896f;
output[threadIdx.x] = value;
static std::mutex completedMutex;
static std::vector<std::pair<uint8_t *, size_t>> completedBuffers;
static void CUPTIAPI requestBuffer(uint8_t **buffer, size_t *size,
size_t *maxRecords) {
*size = 1024 * 1024;
*buffer = static_cast<uint8_t *>(std::malloc(*size));
*maxRecords = 0;
static void CUPTIAPI completeBuffer(CUcontext, uint32_t, uint8_t *buffer,
size_t, size_t validSize) {
std::lock_guard<std::mutex> lock(completedMutex);
completedBuffers.emplace_back(buffer, validSize);
int main(int argc, char **argv) {
if (argc != 2 || (std::strcmp(argv[1], "--hes") != 0 &&
std::strcmp(argv[1], "--no-hes") != 0)) {
std::fprintf(stderr, "usage: %s --hes|--no-hes\n", argv[0]);
return 2;
bool enableHes = std::strcmp(argv[1], "--hes") == 0;
std::printf("HES=%s\n", enableHes ? "on" : "off");
CHECK(cuInit(0));
if (enableHes) {
CHECK(cuptiActivityEnableHWTrace(1));
CHECK(cuptiActivityRegisterCallbacks(requestBuffer, completeBuffer));
CHECK(cuptiActivityEnable(CUPTI_ACTIVITY_KIND_CONCURRENT_KERNEL));
constexpr int threads = 256;
constexpr int elements = 16384;
float *output;
cudaStream_t stream;
cudaGraph_t graph;
cudaGraphExec_t executable;
CHECK(cudaMalloc(&output, elements * sizeof(*output)));
CHECK(cudaStreamCreateWithFlags(&stream, cudaStreamNonBlocking));
CHECK(cudaGraphCreate(&graph, 0));
CUcontext context;
CHECK(cuCtxGetCurrent(&context));
CUDA_MEMSET_NODE_PARAMS memsetParams{};
memsetParams.dst = reinterpret_cast<CUdeviceptr>(output);
memsetParams.value = 0;
memsetParams.elementSize = sizeof(float);
memsetParams.width = elements;
memsetParams.height = 1;
CUgraphNode driverMemsetNode;
CHECK(cuGraphAddMemsetNode(&driverMemsetNode, reinterpret_cast<CUgraph>(graph),
nullptr, 0, &memsetParams, context));
auto memsetNode = reinterpret_cast<cudaGraphNode_t>(driverMemsetNode);
int iterations = 100000;
void *arguments[] = {&output, &iterations};
cudaKernelNodeParams kernelParams{};
kernelParams.func = reinterpret_cast<void *>(kernel);
kernelParams.gridDim = dim3(1);
kernelParams.blockDim = dim3(threads);
kernelParams.kernelParams = arguments;
cudaGraphNode_t kernelNode;
CHECK(cudaGraphAddKernelNode(&kernelNode, graph, &memsetNode, 1,
&kernelParams));
CHECK(cudaGraphInstantiate(&executable, graph));
CHECK(cudaGraphUpload(executable, stream));
CHECK(cudaGraphLaunch(executable, stream));
CHECK(cudaStreamSynchronize(stream));
if (enableHes) {
CHECK(cuptiActivityFlushAll(CUPTI_ACTIVITY_FLAG_FLUSH_FORCED));
for (const auto &buffer : completedBuffers)
std::free(buffer.first);
completedBuffers.clear();
} else {
int count = 0;
for (auto [buffer, validSize] : completedBuffers) {
CUpti_Activity *activity = nullptr;
while (cuptiActivityGetNextRecord(buffer, validSize, &activity) ==
CUPTI_SUCCESS) {
++count;
if (activity->kind == CUPTI_ACTIVITY_KIND_CONCURRENT_KERNEL) {
auto *record = reinterpret_cast<CUpti_ActivityKernel12 *>(activity);
std::printf("activity kind=%u name=%s start=%llu end=%llu\n",
unsigned(record->kind),
record->name ? record->name : "<null>",
static_cast<unsigned long long>(record->start),
static_cast<unsigned long long>(record->end));
} else {
std::printf("activity kind=%u\n", unsigned(activity->kind));
std::free(buffer);
std::printf("activity count=%d\n", count);
CHECK(cuptiActivityDisable(CUPTI_ACTIVITY_KIND_CONCURRENT_KERNEL));
CHECK(cudaGraphExecDestroy(executable));
CHECK(cudaGraphDestroy(graph));
CHECK(cudaStreamDestroy(stream));
CHECK(cudaFree(output));
if (enableHes)
CHECK(cuptiActivityEnableHWTrace(0));
return 0;
