I am willing to read multiple metrics via CUPTI library. I rewrite the sample code “callback_metric” and convert some variables defined in the original source code such as metricName, metricId, metricDatas, etc. to arrays e.g. metricNames, metricIds, metricDatass, etc.
CUpti_SubscriberHandle *subscribers;
char **metricNames;
CUpti_MetricID *metricIds;
CUpti_EventGroupSets **passDatas;
MetricData_t *metricDatas;
CUpti_MetricValue *metricValues;
Everything seems good, unless the line of code that calls the subscriber (assume that there are two desired metrics and therefore two metricDatas, so I defined two subscribers).
CUPTI_CALL(cuptiSubscribe(&subscribers[0], (CUpti_CallbackFunc)getMetricValueCallback, &metricDatas[0]));
CUPTI_CALL(cuptiSubscribe(&subscribers[1], (CUpti_CallbackFunc)getMetricValueCallback, &metricDatas[1]));
In the runtime I get this error:
function cuptiSubscribe(&subscribers[1], (CUpti_CallbackFunc)getMetricValueCallback2, &metricDatas[1]) failed with error CUPTI_ERROR_MAX_LIMIT_REACHED
Is there any better or easy way to read multiple metrics? Is it possible via a single subscriber?
