cuRAND 8.0: Bugs in curandSetGeneratorOffset() with PHILOX4_32_10 and curandGenerateSeeds() with MT19937 ?
I’ve noticed a couple of problems with cuRAND when trying CPU/GPU reproducibility, sequence offset and general performance. I’m using cuRAND 8.0.61 on Windows.
  • Using curandSetGeneratorOffset() with PHILOX4_32_10 seems to return back to the beginning of the sequence no matter the offset. MRG32K3A and XORWOW work fine. See the "ERROR: comparison 8000 failed" message when running the following program (source to follow).
  • Using curandGenerateSeeds() with MT19937 CPU takes about 20-30 seconds (?!), surely that's not right?
Is there anything obvious I’m missing here?
Regards,
Tanguy
#include <cuda.h>
#include <curand.h>
#include <cuda_runtime.h>
#include <chrono>
#include <iostream>
#include <stdexcept>
#include <string>
#include <sstream>
#include <vector>
using namespace std::chrono;
// This will output the proper CUDA error strings in the event that a CUDA host call returns an error
#define CheckCudaError(val)           __checkCudaError ( (val), #val, __FILE__, __LINE__ )
#define CheckCuRandError(val)         __checkCuRandError ( (val), #val, __FILE__, __LINE__ )
class CudaException : public std::runtime_error
public:
	CudaException(cudaError_t cudaError, const std::string & msg) :
		runtime_error(msg),
		CudaError(cudaError) { }
	const cudaError_t CudaError;
class CuRandException : public std::runtime_error
public:
	CuRandException(curandStatus_t cuRandError, const std::string & msg) :
		runtime_error(msg),
		CuRandError(cuRandError) { }
	const curandStatus_t CuRandError;
inline void __checkCudaError(cudaError_t result, char const *const func, const char *const file, int const line)
	if (result)
		std::ostringstream out;
		out << "CUDA error at "
			<< file << ":" << line
			<< " code=" << static_cast<unsigned int>(result)
			<< " (" << cudaGetErrorString(result) << ") "
			<< "'" << func << "'";
		throw CudaException(result, out.str());
inline void __checkCuRandError(curandStatus_t result, char const *const func, const char *const file, int const line)
	if (result)
		out << "cuRAND error at "
		throw CuRandException(result, out.str());
class CuRandom
public:
	CuRandom(bool cpu, curandRngType_t rngType) :
		cpu_(cpu),
		hBuffer_(BufferSize),
		pos_(BufferSize)
		CheckCudaError(cudaMalloc(&dBuffer_, BufferSize * sizeof(float)));
		CheckCuRandError(cpu ? curandCreateGeneratorHost(&generator_, rngType) : curandCreateGenerator(&generator_, rngType));
		// Precompute the seeds and time it separately.
			auto begin = high_resolution_clock::now();
			CheckCuRandError(curandGenerateSeeds(generator_));
			auto end = high_resolution_clock::now();
			auto elapsed = duration_cast<nanoseconds>(end - begin).count();
			std::cout << "Generated " << (cpu_ ? "CPU" : "GPU") << " seeds in " << elapsed / (1000.0*1000.0) << "ms" << std::endl;
	~CuRandom()
		CheckCuRandError(curandDestroyGenerator(generator_));
		CheckCudaError(cudaFree(dBuffer_));
	float NextFloat()
		if (pos_ >= BufferSize)
			RefillBuffer();
			pos_ = 0;
		return hBuffer_[pos_++];
	void SetOffset(unsigned long long offset)
		CheckCuRandError(curandSetGeneratorOffset(generator_, offset));
		pos_ = BufferSize;
		std::cout << "Set " << (cpu_ ? "CPU" : "GPU") << "offset " << offset << " in " << elapsed / (1000.0*1000.0) << "ms" << std::endl;
private:
	void RefillBuffer()
		if (cpu_)
			CheckCuRandError(curandGenerateUniform(generator_, hBuffer_.data(), BufferSize));
		else
			CheckCuRandError(curandGenerateUniform(generator_, dBuffer_, BufferSize));
			CheckCudaError(cudaMemcpy(hBuffer_.data(), dBuffer_, BufferSize * sizeof(float), cudaMemcpyDeviceToHost));
		std::cout << "Refilled " << (cpu_ ? "CPU" : "GPU") << "buffer in " << elapsed / (1000.0*1000.0) << "ms" << std::endl;
	const size_t BufferSize = 8 * 1024 * 1024;
	const bool cpu_;
	curandGenerator_t generator_;
	std::vector<float> hBuffer_;
	float* dBuffer_;
	size_t pos_;
void RunComparisons();
void RunComparison(curandRngType_t rngType, const char* name, size_t numComparisons);
int main(int argc, char *argv[])
	try
		int cuRandVersion;
		CheckCuRandError(curandGetVersion(&cuRandVersion));
		std::cout << "cuRAND version: " << cuRandVersion << std::endl;
		std::cout << std::endl;
		RunComparisons();
	catch (const std::exception& exception)
		std::cout << "ERROR: " << exception.what() << std::endl;
	const size_t numComparisons = 16 * 1000 * 1000;
	RunComparison(CURAND_RNG_PSEUDO_MT19937, "MT19937", numComparisons);
	RunComparison(CURAND_RNG_PSEUDO_MTGP32, "MTGP32", numComparisons);
	RunComparison(CURAND_RNG_PSEUDO_MRG32K3A, "MRG32K3A", numComparisons);
	RunComparison(CURAND_RNG_PSEUDO_XORWOW, "XORWOW", numComparisons);
	RunComparison(CURAND_RNG_PSEUDO_PHILOX4_32_10, "PHILOX4_32_10", numComparisons);
void RunComparison(curandRngType_t rngType, const char* const name, size_t numComparisons)
	std::cout << "Running " << numComparisons << " comparisons for '" << name << "'..." << std::endl;
	CuRandom refRand(true, rngType);
	CuRandom cpuRand(true, rngType);
	CuRandom gpuRand(false, rngType);
	for (int i = 0; i != numComparisons; ++i)
		// Check offset setting on RNG that supports it.
		if (i == 8000 && rngType != CURAND_RNG_PSEUDO_MT19937 && rngType != CURAND_RNG_PSEUDO_MTGP32)
			const int offset = i + 3;
			// Move reference RNG by repeatedly calling NextFloat().
			for (int j = i; j != offset; ++j)
				refRand.NextFloat();
			cpuRand.SetOffset(offset);
			gpuRand.SetOffset(offset);
		float r = refRand.NextFloat();
		float c = cpuRand.NextFloat();
		float g = gpuRand.NextFloat();
		if (i == 0)
			std::cout << "First: " << r << std::endl;
		if (r != c || c != g)
			std::cout
				<< "ERROR: comparison " << i << " failed for '" << name
				<< "' (" << r << " != " << c << " || " << c << " != " << g << ")"
				<< std::endl;
			break;
	std::cout << "Ran comparison in " << elapsed / (1000.0*1000.0) << "ms" << std::endl;
I’ve reported internal NVIDIA bug #1922632 for the PHILOX generator offset issue.
If there are meaningful developments, I will advise. Until then, requests for additional information may or may not be responded to. I’m not 100% sure this is a bug in the code (could be a documentation bug) but until there is response by the development teams, I won’t be able to offer any additional information. I have no information on workarounds at this time, except to either not use that function or use that function with a different generator type.
