im trying to use curand_normal2 inside a kernel of mine but I have a problem.As you can see below i store the result from the curand_normal2() in a float2 variable.The problem is that the numbers generated vary inside (-7,7). This variation is huge for my application.It would be ideal if Ι could limit it inside (0,1).
__global__ void kernel(... , .... , .... , .... , .... , .... ,unsigned long long seed) {
curandStateXORWOW_t localState; //I tried curandState too
float2 no;
curand_init(seed , blockIdx.x*BLOCK_SIZE+threadIdx.x, 0,&localState);
for(k=0;k<L;k++)
no=curand_normal2(&localState);
I know that with something like this:
no.x=powf(no.x/7,2);
i would nearly overcome the problem but
1)it takes so much computing time
2)Not normal distribution.Most of the numbers are near zero
PS
kernel(120,192)
L=5000
in case it matters
Thanks for your time
