curand_uniform() problem Can't find out why kernell crashes with curand_unifor
Hello dear sirs,
I am student from Russia, working on my course work (Monte-Carlo method for solving sparse SLAE on GPU) and i can’t find out why my kernell crashes, when i use curand_uniform() function from library CURAND. May be someone can help me to understand my mistakes, I am in deep depression because I can’t understand what i am doing wrong in whole week. Here i post kernel code and host code. Deeply sorry for my English!
Kernel launche code:
devP is a pointer to 1 dimensional massive of floats; devV, devColInd, devOffsets is a pointers to 1 dimensional massive of ints. This massives (devP, devColInd, devOffsets) discribes sparse matrix in compressed raw format, devV is additional data to this matrix.
testKernel<<<1, 1>>>(devP, devV, devColInd, devOffsets, B, time(NULL), stohNum, devRes);
	cudaError_t error = cudaGetLastError();
	if(error != cudaSuccess)
		printf("Cuda error: %s\n", cudaGetErrorString(error));
		printf("Press enter to quit with -1 code\n");
		getchar();
		exit(-1);
When I check kernel execution with cuda error i get “unknown error”
Kernel definition code:
__global__ void testKernel(float *p, int *v, int *colInd, int *offsets, float *B, unsigned long seed, int numStoh, float *res)
	int gid = threadIdx.x;
	int counter = 0;
	float xx = 0.0, x = 0.0;
	float rNum = 0.0;
	float accSum = 0.0;
	int vv = 1;
	int curEq = 0;// kp = 0;
	int exit = 0;
	int isFound = 0;
	int root = 1;
	curandState localState;
	curand_init(seed, gid, 0, &localState);
	while(counter < numStoh)
		curEq = root;
		xx = B[root];
		vv = 1;
		exit = 0;
		while(!exit)//create Markov's chain
			//kp = k; //save previos state
			rNum = curand_uniform(&localState);//((float)rand()/((float)RAND_MAX));
			accSum = 0.0;
			isFound = 0;
			for(int j = 0; j < offsets[curEq+1] - offsets[curEq]; j++)
				if(((rNum > accSum) && (rNum < accSum + p[offsets[curEq] + j])) || (rNum == accSum))
					vv = vv*v[offsets[curEq] + j];
					curEq = colInd[offsets[curEq] +j];
					xx = xx + vv*B[curEq];
					isFound = 1;
					break;
				accSum += p[offsets[curEq] + j];
			if(isFound != 1)//particle reach the border
				exit = 1;
		x += xx;
		counter++;
	res[0] = x;
if I for example cooment line with curand_uniform() and replace it with rNum = 0.99 then kernel will finish execution with ok status, may there is a problem with massives but i checked it thousands times. So I have not ideas whats wrong…
Your use of the curand library looks fine to me. But I suspect an error elsewhere in your code. Actually, I faced the very same problem with mine, whereby a call to curand_uniform was triggering a crash that was latent in the code, following to a previous out of bound error…
I encourage you to check your code with cuda_memcheck to see if it spots anything of this kind.
Great thanks to your advice, I’ll try it!
