Curobo MotionGenStatus.INVALID_START_STATE_JOINT_LIMITS
Isaac Sim Version
4.0.0
Operating System
Ubuntu 22.04
GPU Information
  • Model: RTX3080
  • Driver Version: 550.120
Topic Description
I have been setting up curobo as a solver for our custom robot at work. I am using a modified multi_arm_reacher.py although the core of code is same. I have pasted the file if needed.
Everything works fine, except for one error that stops the entire simulaiton and I need to restart the simulation: MotionGenStatus.INVALID_START_STATE_JOINT_LIMITS. This doesn’t happen at the beginning, but rather when in the previous generated motion, one of the joints exceeds the joint limits.
I’ve been printing joint positions to confirm. I would’ve expected that the solver would not generate a path which would take some joints beyond their limits to begin with. Can you help me understand why this is happening? Is there a way to avoid this or increase the joint limit tolerances?
Thank You.
code:
try:
    # Third Party
    import isaacsim
except ImportError:
    pass
# Third Party
import torch
import zmq
import time
a = torch.zeros(4, device="cuda:0")
# Standard Library
import argparse
parser = argparse.ArgumentParser()
parser.add_argument(
    "--headless_mode",
    type=str,
    default=None,
    help="To run headless, use one of [native, websocket], webrtc might not work.",
    "--robot", type=str, default="dual_ur10e.yml", help="robot configuration to load"
args = parser.parse_args()
# Third Party
from omni.isaac.kit import SimulationApp
simulation_app = SimulationApp(
        "headless": args.headless_mode is not None,
        "width": "1920",
        "height": "1080",
# Third Party
import carb
import numpy as np
from omni.isaac.core import World
from omni.isaac.core.objects import cuboid, sphere
########### OV #################
from omni.isaac.core.utils.types import ArticulationAction
from omni.isaac.core.articulations import Articulation
# CuRobo
from curobo.cuda_robot_model.cuda_robot_model import CudaRobotModel
# from curobo.wrap.reacher.ik_solver import IKSolver, IKSolverConfig
from curobo.geom.sdf.world import CollisionCheckerType
from curobo.geom.types import WorldConfig
from curobo.rollout.rollout_base import Goal
from curobo.types.base import TensorDeviceType
from curobo.types.math import Pose
from curobo.types.robot import JointState, RobotConfig
from curobo.types.state import JointState
from curobo.util.logger import setup_curobo_logger
from curobo.util.usd_helper import UsdHelper
from curobo.util_file import get_robot_configs_path, get_world_configs_path, join_path, load_yaml
from curobo.wrap.reacher.motion_gen import MotionGen, MotionGenConfig, MotionGenPlanConfig
import os
import sys
sys.path.append(os.path.dirname(os.path.dirname(os.path.dirname(os.path.dirname(os.path.dirname(os.path.dirname(os.path.__file__)))))))
print(f'PATH: {sys.path}')
from helper import add_extensions, add_robot_to_scene
class MultiArmControl:
    def __init__(self, transmit_data = False):
        self.transmit_data = transmit_data # to send current js
        self.setup()
    def setup(self):
        # assuming obstacles are in objects_path:
        self.my_world = World(stage_units_in_meters=1.0)
        self.stage = self.my_world.stage
        self.xform = self.stage.DefinePrim("/World", "Xform")
        self.stage.SetDefaultPrim(self.xform)
        self.stage.DefinePrim("/curobo", "Xform")
        # my_world.stage.SetDefaultPrim(my_world.stage.GetPrimAtPath("/World"))
        # stage.SetDefaultPrim(stage.GetPrimAtPath("/World"))
        # Make a target to follow
        setup_curobo_logger("warn")
        self.past_pose = None
        self.n_obstacle_cuboids = 30
        self.n_obstacle_mesh = 10
        # warmup curobo instance
        self.usd_help = UsdHelper()
        self.target_pose = None
        self.tensor_args = TensorDeviceType()
        self.robot_cfg = load_yaml(join_path(get_robot_configs_path(), args.robot))["robot_cfg"]
        self.j_names = self.robot_cfg["kinematics"]["cspace"]["joint_names"]
        self.default_config = self.robot_cfg["kinematics"]["cspace"]["retract_config"]
        # self.robot_name = "robot_{}".format(np.random.randint(0, 1000))  # Generate a unique robot name
        self.robot, self.robot_prim_path = add_robot_to_scene(self.robot_cfg, self.my_world)#, robot_name=self.robot_name)
        self.articulation_controller = self.robot.get_articulation_controller()
        self.world_cfg_table = WorldConfig.from_dict(
            load_yaml(join_path(get_world_configs_path(), "collision_table.yml"))
        self.world_cfg_table.cuboid[0].pose[2] -= 0.02
        self.world_cfg1 = WorldConfig.from_dict(
        ).get_mesh_world()
        self.world_cfg1.mesh[0].name += "_mesh"
        self.world_cfg1.mesh[0].pose[2] = -10.5
        self.world_cfg = WorldConfig(cuboid=self.world_cfg_table.cuboid, mesh=self.world_cfg1.mesh)
        self.motion_gen_config = MotionGenConfig.load_from_robot_config(
            self.robot_cfg,
            self.world_cfg,
            self.tensor_args,
            collision_checker_type=CollisionCheckerType.MESH,
            use_cuda_graph=True,
            interpolation_dt=0.03,
            collision_cache={"obb": self.n_obstacle_cuboids, "mesh": self.n_obstacle_mesh},
            collision_activation_distance=0.025,
            fixed_iters_trajopt=True,
            maximum_trajectory_dt=0.5,
            position_threshold = 0.5,
            rotation_threshold = 0.5
        self.motion_gen = MotionGen(self.motion_gen_config)
        print("warming up...")
        self.motion_gen.warmup(enable_graph=True, warmup_js_trajopt=False)
        print("Curobo is Ready")
        add_extensions(simulation_app, args.headless_mode)
        self.plan_config = MotionGenPlanConfig(
            enable_graph=False,
            enable_graph_attempt=4,
            max_attempts=10,
            time_dilation_factor=0.8,
        self.usd_help.load_stage(self.my_world.stage)
        self.usd_help.add_world_to_stage(self.world_cfg, base_frame="/World")
        self.cmd_plan = None
        self.cmd_idx = 0
        self.my_world.scene.add_default_ground_plane()
        self.i = 0
        self.spheres = None
        # read number of targets in link names:
        self.link_names = self.motion_gen.kinematics.link_names
        self.ee_link_name = self.motion_gen.kinematics.ee_link
        # get link poses at retract configuration:
        self.kin_state = self.motion_gen.kinematics.get_state(self.motion_gen.get_retract_config().view(1, -1))
        self.link_retract_pose = self.kin_state.link_pose
        self.t_pos = np.ravel(self.kin_state.ee_pose.to_list())
        self.target = cuboid.VisualCuboid(
            "/World/target",
            position=self.t_pos[:3],
            orientation=self.t_pos[3:],
            color=np.array([1.0, 0, 0]),
            size=0.05,
        # create new targets for new links:
        self.ee_idx = self.link_names.index(self.ee_link_name)
        self.target_links = {}
        self.names = []
        for i in self.link_names:
            if i != self.ee_link_name:
                k_pose = np.ravel(self.link_retract_pose[i].to_list())
                color = np.random.randn(3) * 0.2
                color[0] += 0.5
                color[1] = 0.5
                color[2] = 0.0
                self.target_links[i] = cuboid.VisualCuboid(
                    "/World/target_" + i,
                    position=np.array(k_pose[:3]),
                    orientation=np.array(k_pose[3:]),
                    color=color,
                    size=0.05,
                self.names.append("/World/target_" + i)
        self.i = 0
        self.step_index = 0
        self.left_ee_prim = Articulation(prim_path = "/RoboticArms/left_ee_link")
        self.right_ee_prim = Articulation(prim_path = "/RoboticArms/right_ee_link")
        if self.transmit_data:
            self.zmq_publisher = zmq.Context()
            self.zmq_publisher = self.zmq_publisher.socket(zmq.REP)
            self.zmq_publisher.bind("tcp://*:5575")
    def step_ik(self,
                target_position_left=None,
                target_orientation_left=None,
                target_position_right=None,
                target_orientation_right=None):
        # left arm control:
        if target_position_left is not None:
            print("setting left target")
            self.target_links["left_ee_link"].set_world_pose(position=target_position_left, orientation=target_orientation_left)
        # right arm control:
        if target_position_right is not None:
            print("setting right target")
            self.target.set_world_pose(position=target_position_right, orientation=target_orientation_right)
        # position and orientation of target virtual cube:
        cube_position, cube_orientation = self.target.get_world_pose()
        # print(f'cube position: {cube_position}   cube orientation: {cube_orientation}')
        # for i in self.target_links.keys():
        #     c_p, c_rot = self.target_links[i].get_world_pose()
        #     print(f'c_p: {c_p}   c_rot: {c_rot}')
        right_ee_pos, right_ee_or = self.right_ee_prim.get_world_pose()
        left_ee_pos, left_ee_or = self.left_ee_prim.get_world_pose()
        # print(f'right pos: {right_ee_pos}   right or: {right_ee_or}')
        # print(f'left pos: {left_ee_pos}   left or: {left_ee_or}')
        if self.past_pose is None:
            self.past_pose = cube_position
        if self.target_pose is None:
            self.target_pose = cube_position
        sim_js = self.robot.get_joints_state()
        sim_js_names = self.robot.dof_names
        cu_js = JointState(
            position=self.tensor_args.to_device(sim_js.positions),
            velocity=self.tensor_args.to_device(sim_js.velocities) * 0.0,
            acceleration=self.tensor_args.to_device(sim_js.velocities) * 0.0,
            jerk=self.tensor_args.to_device(sim_js.velocities) * 0.0,
            joint_names=sim_js_names,
        cu_js = cu_js.get_ordered_joint_state(self.motion_gen.kinematics.joint_names)
        print(sim_js_names)
        print(sim_js.positions)
        # print(sim_js.velocities)
        # print(f"MAX: {np.max(np.abs(sim_js.velocities))}")
        if (
            np.linalg.norm(cube_position - self.target_pose) > 1e-6
            # and np.linalg.norm(past_pose - cube_position) == 0.0
            # and np.max(np.abs(sim_js.velocities)) < 0.2
            print("1")
            # Set EE teleop goals, use cube for simple non-vr init:
            ee_translation_goal = cube_position
            ee_orientation_teleop_goal = cube_orientation
            print("2")
            # compute curobo solution:
            ik_goal = Pose(
                position=self.tensor_args.to_device(ee_translation_goal),
                quaternion=self.tensor_args.to_device(ee_orientation_teleop_goal),
            print("3")
            # add link poses:
            link_poses = {}
                link_poses[i] = Pose(
                    position=self.tensor_args.to_device(c_p),
                    quaternion=self.tensor_args.to_device(c_rot),
            print("4")
            result = self.motion_gen.plan_single(
                cu_js.unsqueeze(0), ik_goal, self.plan_config.clone(), link_poses=link_poses
            # ik_result = ik_solver.solve_single(ik_goal, cu_js.position.view(1,-1), cu_js.position.view(1,1,-1))
            print("5")
            succ = result.success.item()  # ik_result.success.item()
            print("6")
            if succ:
                self.cmd_plan = result.get_interpolated_plan()
                self.cmd_plan = self.motion_gen.get_full_js(self.cmd_plan)
                # get only joint names that are in both:
                self.idx_list = []
                common_js_names = []
                for x in sim_js_names:
                    if x in self.cmd_plan.joint_names:
                        self.idx_list.append(self.robot.get_dof_index(x))
                        common_js_names.append(x)
                # idx_list = [robot.get_dof_index(x) for x in sim_js_names]
                self.cmd_plan = self.cmd_plan.get_ordered_joint_state(common_js_names)
                self.cmd_idx = 0
                print("7")
            else:
                carb.log_warn("Plan did not converge to a solution: " + str(result.status))
            print("8")
            print("9")
        # print("10")
        if self.cmd_plan is not None:
            self.cmd_state = self.cmd_plan[self.cmd_idx]
            # get full dof state
            art_action = ArticulationAction(
                self.cmd_state.position.cpu().numpy(),
                self.cmd_state.velocity.cpu().numpy(),
                joint_indices=self.idx_list,
            print("11")
            self.art_action = art_action
            # print(f'art_action: {art_action}')
            # set desired joint angles obtained from IK:
            self.articulation_controller.apply_action(art_action)
            ########### UPDATE for Req-Rep
            # if self.transmit_data:
            #     self.zmq_publisher.send_pyobj(art_action)
            print("12")
            self.cmd_idx += 1
            for _ in range(2):
                self.my_world.step(render=False)
            if self.cmd_idx >= len(self.cmd_plan.position):
                self.cmd_idx = 0
            print("13")
def test_general():
    MultiArmController = MultiArmControl()
    while simulation_app.is_running():
        try:
            # ------------------ Run Once ------------------
            MultiArmController.my_world.step(render=True)
            if not MultiArmController.my_world.is_playing():
                if MultiArmController.i % 100 == 0:
                    print("**** Click Play to start simulation *****")
                MultiArmController.i += 1
                # if step_index == 0:
                #    my_world.play()
                continue
            MultiArmController.step_index = MultiArmController.my_world.current_time_step_index
            if MultiArmController.step_index <= 2:
                MultiArmController.my_world.reset()
                MultiArmController.idx_list = [MultiArmController.robot.get_dof_index(x) for x in MultiArmController.j_names]
                MultiArmController.robot.set_joint_positions(MultiArmController.default_config, MultiArmController.idx_list)
                MultiArmController.robot._articulation_view.set_max_efforts(
                    values=np.array([5000 for MultiArmController.i in range(len(MultiArmController.idx_list))]), joint_indices=MultiArmController.idx_list
            if MultiArmController.step_index < 20:
                continue
            if MultiArmController.step_index == 50 or MultiArmController.step_index % 1000 == 0.0:
                print("Updating world, reading w.r.t.", MultiArmController.robot_prim_path)
                obstacles = MultiArmController.usd_help.get_obstacles_from_stage(
                    # only_paths=[obstacles_path],
                    reference_prim_path=MultiArmController.robot_prim_path,
                    ignore_substring=[
                        "/World/target",
                        "/World/defaultGroundPlane",
                        "/curobo",
                    + MultiArmController.names,
                ).get_collision_check_world()
                MultiArmController.motion_gen.update_world(obstacles)
                print("Updated World")
                carb.log_info("Synced CuRobo world from stage.")
            # -------------------- ARM CONTROL --------------------
                    #set world pose
            # print("going into step_ik")
            MultiArmController.step_ik()
            # print("getting out of step_ik")
Hey @sanskar1 . There is a warning for curobo multi arm reacher example:
Multi-Arm motion planning is experimental and does not work as well as single arm planning. There are open research questions on how to solve multi-arm planning and cuRobo’s current implementation is only meant to be a starting point for research in this area.
Maybe you could do some research and implement your own multi-arm motion planning algorithm?
How can I contribute to curobo’s research?
Hi @sanskar1. Unfortunately we don’t have a way to add third party research code to curobo at the moment. You can use curobo as a python dependency and build on top of it.
Our engineer shared this research work which improved cuRobo’s dual arm motion planning quality. I hope this information is helpful for you.
I will close this topic since there is no new replies. But please feel free to open a new one if the issue still persists.
