The Tegra K1 datasheet does not give the peak current consumption of these domains: AVDD_PLL_APC2C3,AVDD_PLL_C4, AVDD_PLL_CG, AVDD_PLL_EREFE, AVDD_PLL_M, AVDD_PLL_X, VDDIO_DDR_HS ; also they are tied together alongwith AVDD_LVDS0_IO to +1.05V_RUN_AVDD rail provided by LDO0 of PMIC in the Jetson Board, however there is no 0 Ohm nor a sense res so that one could measure the current.Has anybody got current consumption details for this?
