I want to create a packer image for auto-installing. I wonder if you have dgx_a100-curtin.yaml and a preseed.sh template.
Hi @pordonez ,
We have instructions for where to find the curtin file in the PXE section of the DGX OS 5 User Guide. You might also take a look at the DeepOps MaaS documentation, specifically the DGX section at the bottom.
Does that get you what you need?
ScottE
Scott,
You might also take a look at the DeepOps MaaS documentation, specifically the DGX section at the bottom?
Using this approach, will install Ubuntu 20.04 on the first SSD (nvme1n1 3.4TB), which is not our goal. Besides, it doesn’t install the OFED, NVIDIA and other software.
Our goal is to install the OS as raid 1 on nvme2n1 and nvme3n1 ssd’s. Below is the curtin storage script; however, I got an error (look below).
Any help is more than welcome.
Curtin script
storage:
version: 1
config:
- id: nvme2n1
type: disk
ptable: gpt
path: /dev/nvme2n1
wipe: superblock-recursive
- id: nvme3n1
type: disk
ptable: gpt
path: /dev/nvme3n1
- id: nvme2n1-part1
type: partition
device: nvme2n1
number: 1
flag: boot
- id: nvme3n1-part1
type: partition
device: nvme3n1
number: 1
flag: boot
- id: nvme2n1-part2
type: partition
device: nvme2n1
number: 2
flag: raid
- id: nvme3n1-part2
type: partition
device: nvme3n1
number: 2
flag: raid
- id: md_device0
type: raid
raidlevel: 1
devices:
- nvme2n1-part2
- nvme3n1-part2
- id: nvme2n1-part1-fs1
type: format
fstype: fat32
label: boot
volume: nvme2n1-part1
- id: md_root
type: format
fstype: ext4
volume: md_device0
- id: md_mount
type: mount
path: /
device: md_root
options: errors=remount-ro
passno: 1
- id: boot_mount
type: mount
path: /boot/efi
device: nvme2n1-part1-fs1
passno: 1
Error
Error rescanning devices, possibly known issue LP: #1489521
cmd: ['blockdev', '--rereadpt', '/dev/nvme2n1']
stdout:''
stderr:blockdev: ioctl error on BLKRRPART: Device or resource busy
exit_code:1
