The sample code you pointed to allocates several arrays on the stack used by main(). In the example, these arrays are fairly “small”.
By increasing batch_size, m, and n you are making the stack allocations “large”, which cause the available stack space to be exceeded, which triggers the exception you observe.
Potential solutions:
[1] Placing large allocation in the stack is typically considered bad practice. Large allocations are usually allocated in the heap; use malloc() or equivalent functions to allocate data there.
[2] Use compiler switches to increase the default stack size. As I recall in MSVC there is a compiler switch /F to do that and also a linker switch /STACK. I forget whether one is a subset of the other, or whether they are true alternatives.
