CUSPARSE Documentation Error
Hello, I was looking at both the PDF and HTML manual for CUSPARSE. The function csr2dense has incorrect information for the call to the functions. It specifies csr2csc code.
Also, on a side note, the documentation says csr2csc can be be used in reverse, but doesn’t specify how. How can I do this?
Thanks for notifying this documentation error.
About csr2csc, you can simply use it directly as “csc2csr”, using your csc matrix as an input and you will get a csr as an output.
Thank you for the help philippev!
