I tryed to repeat example from Cusparse Libarary Manual (p.141) and added some code to realize it. But cusparseXcsrilu02_zeroPivot returns cusparse_status_internal_error everytime when I try to start program. What I did wrong? By the way, there are some mistakes in manual’s example. Some arguments were lost in some functions, but it’s easy to be corrected. I wonder anybody can help me with my problem. This is my code:
int solve()
cusparseStatus_t status;
cusparseHandle_t handle=0;
cusparseCreate(&handle);
int m=5, nnz=12;
double csrVal[12]={2, 4 ,4 ,4, 3 ,3,3,4,5};
int col[12]={0, 1, 1, 2,2,3,3,4,4 };
int rowptr[6]={0, 2, 4, 6, 8, 9 };
double ans[6], rh[6]={4, 5, 6,3,1};
double *d_csrVal, *d_x,*d_y, *d_z;
int *d_csrRowPtr, *d_csrColInd;
cudaMalloc((void **)&d_csrVal, nnz*sizeof(double));
cudaMalloc((void **)&d_csrColInd, nnz*sizeof(int));
cudaMalloc((void **)&d_csrRowPtr, (m+1)*sizeof(int));
cudaMalloc((void **)&d_x, m*sizeof(double));
cudaMalloc((void **)&d_z, m*sizeof(double));
cudaMalloc((void **)&d_y, m*sizeof(double));
cudaMemcpy(d_csrVal,csrVal,nnz*sizeof(double),cudaMemcpyHostToDevice);
cudaMemcpy(d_csrColInd,col,nnz*sizeof(int),cudaMemcpyHostToDevice);
cudaMemcpy(d_csrRowPtr,rowptr,(m+1)*sizeof(double),cudaMemcpyHostToDevice);
cudaMemcpy(d_x,rh,(m)*sizeof(double),cudaMemcpyHostToDevice);
// Suppose that A is m x m sparse matrix represented by CSR format,
// Assumption: // - handle is already created by cusparseCreate(),
// - (d_csrRowPtr, d_csrColInd, d_csrVal) is CSR of A on device memory,
// - d_x is right hand side vector on device memory,
// - d_y is solution vector on device memory.
// - d_z is intermediate result on device memory.
cusparseMatDescr_t descr_M = 0;
cusparseMatDescr_t descr_L = 0;
cusparseMatDescr_t descr_U = 0;
csrilu02Info_t info_M = 0;
csrsv2Info_t info_L = 0;
csrsv2Info_t info_U = 0;
int pBufferSize_M;
int pBufferSize_L;
int pBufferSize_U;
int pBufferSize;
char *pBuffer = 0;
int structural_zero;
int numerical_zero;
const double alpha = 1.;
const cusparseSolvePolicy_t policy_M = CUSPARSE_SOLVE_POLICY_NO_LEVEL;
const cusparseSolvePolicy_t policy_L = CUSPARSE_SOLVE_POLICY_NO_LEVEL;
const cusparseSolvePolicy_t policy_U = CUSPARSE_SOLVE_POLICY_USE_LEVEL;
const cusparseOperation_t trans_L = CUSPARSE_OPERATION_NON_TRANSPOSE;
const cusparseOperation_t trans_U = CUSPARSE_OPERATION_NON_TRANSPOSE;
// step 1: create a descriptor which contains
// - matrix M is base-1
// - matrix L is base-1
// - matrix L is lower triangular
// - matrix L has unit diagonal
// - matrix U is base-1
// - matrix U is upper triangular
// - matrix U has non-unit diagonal
cusparseCreateMatDescr(&descr_M);
cusparseSetMatIndexBase(descr_M, CUSPARSE_INDEX_BASE_ONE);
cusparseSetMatType(descr_M, CUSPARSE_MATRIX_TYPE_GENERAL);
cusparseCreateMatDescr(&descr_L);
cusparseSetMatIndexBase(descr_L, CUSPARSE_INDEX_BASE_ONE);
cusparseSetMatType(descr_L, CUSPARSE_MATRIX_TYPE_GENERAL);
cusparseSetMatFillMode(descr_L, CUSPARSE_FILL_MODE_LOWER);
cusparseSetMatDiagType(descr_L, CUSPARSE_DIAG_TYPE_UNIT);
cusparseCreateMatDescr(&descr_U);
cusparseSetMatIndexBase(descr_U, CUSPARSE_INDEX_BASE_ONE);
cusparseSetMatType(descr_U, CUSPARSE_MATRIX_TYPE_GENERAL);
cusparseSetMatFillMode(descr_U, CUSPARSE_FILL_MODE_UPPER);
cusparseSetMatDiagType(descr_U, CUSPARSE_DIAG_TYPE_NON_UNIT);
// step 2: create a empty info structure
// we need one info for csrilu02 and two info's for csrsv2
cusparseCreateCsrilu02Info(&info_M);
cusparseCreateCsrsv2Info(&info_L);
cusparseCreateCsrsv2Info(&info_U);
// step 3: query how much memory used in csrilu02 and csrsv2, and allocate the buffer
cusparseDcsrilu02_bufferSize(handle, m, nnz, descr_M, d_csrVal, d_csrRowPtr, d_csrColInd,info_M, &pBufferSize_M);
cusparseDcsrsv2_bufferSize(handle, trans_L, m, nnz, descr_L, d_csrVal, d_csrRowPtr, d_csrColInd,info_L, &pBufferSize_L);
cusparseDcsrsv2_bufferSize(handle, trans_U, m, nnz, descr_U, d_csrVal, d_csrRowPtr, d_csrColInd,info_U, &pBufferSize_U);
pBufferSize = max1(pBufferSize_M, max1(pBufferSize_L, pBufferSize_U));
// pBuffer returned by cudaMalloc is automatically aligned to 128 bytes.
cudaMalloc((void**)&pBuffer, pBufferSize);
// step 4: perform analysis of incomplete Cholesky on M
// perform analysis of triangular solve on L
// perform analysis of triangular solve on U
// The lower(upper) triangular part of M has the same sparsity pattern as L(U),
// we can do analysis of csrilu0 and csrsv2 simultaneously.
cusparseDcsrilu02_analysis(handle, m, nnz, descr_M, d_csrVal, d_csrRowPtr, d_csrColInd, info_M, policy_M, pBuffer);
status = cusparseXcsrilu02_zeroPivot(handle, info_M, &structural_zero);
if (CUSPARSE_STATUS_ZERO_PIVOT == status)
printf("A(%d,%d) is missing\n", structural_zero, structural_zero);
cusparseDcsrsv2_analysis(handle, trans_L, m, nnz, descr_L, d_csrVal, d_csrRowPtr, d_csrColInd, info_L, policy_L, pBuffer);
cusparseDcsrsv2_analysis(handle, trans_U, m, nnz, descr_U, d_csrVal, d_csrRowPtr, d_csrColInd, info_U, policy_U, pBuffer);
// step 5: M = L * U cusparseDcsrilu02(handle, m, nnz, descr_M, d_csrVal, d_csrRowPtr, d_csrColInd, info_M, policy_M, pBuffer);
status = cusparseXcsrilu02_zeroPivot(handle, info_M, &numerical_zero);
printf("U(%d,%d) is zero\n", numerical_zero, numerical_zero);
// step 6: solve L*z = x
cusparseDcsrsv2_solve(handle, trans_L, m, nnz, &alpha, descr_L, d_csrVal, d_csrRowPtr, d_csrColInd, info_L, d_x, d_z, policy_L, pBuffer);
// step 7: solve U*y = z
cusparseDcsrsv2_solve(handle, trans_U, m, nnz, &alpha, descr_U, d_csrVal, d_csrRowPtr, d_csrColInd, info_U, d_z, d_y, policy_U, pBuffer);
// step 8: free resources
cudaMemcpy(ans,d_y,(m)*sizeof(double),cudaMemcpyDeviceToHost);
cudaFree(pBuffer);
cudaFree(d_csrVal);
cudaFree(d_csrColInd);
cudaFree(d_csrRowPtr);
cudaFree(d_x);
cudaFree(d_z);
cudaFree(d_y);
cusparseDestroyMatDescr(descr_M);
cusparseDestroyMatDescr(descr_L);
cusparseDestroyMatDescr(descr_U);
cusparseDestroyCsrilu02Info(info_M);
cusparseDestroyCsrsv2Info(info_L);
cusparseDestroyCsrsv2Info(info_U);
cusparseDestroy(handle);
return 0;
